Introduction: How to Control Bulb by Using Arduino UNO and Single Channel 5V Solid State Relay Module
Description:
Compares with the traditional mechanical relay, the Solid State Relay (SSR) has many advantages: it has a longer life, with a much higher turn on/off speed and no noise. Besides, it also has better resistance to vibration and mechanical shock, and better moisture proof performance.
Specification:
- Control Voltage:5V
- Static Current:0mA
- Working Current:13.8mA
- Size: 25mm x 34mm x 25mm (Length*Width*Height)
- Input voltage: 5V DC
- Maximum Output Current: 2A
- Maximum Output Voltage: 240V AC
- Input Voltage of Control Signal: 0-2.5V (low level state), the relay will be on; 3-5V (high level state), the relay will be off.
- Triggered at low level
Step 1: Material Preparation
The photo above shows item needed in this tutorial:
