Introduction: How to Control a Motor Through a Serial Port Without a Microcontroller
You don’t need an Arduino, PIC or any other microcontroller to make a robot. It’s possible to connect your project directly to a computer through a usb port, using a serial-usb adapter (or directly through a serial port if your computer has one). This will let you attach wheels to your laptop and drive it around your apartment without having to buy an extra Arduino, or whatever project you can imagine. USB-Serial adapters can be very cheap ($4 USD) so they make a nice alternative to microcontrollers for simple projects.
Need:
USB-Serial adapter (RS-232)
Motor bridge (TA7291P or others)
One or Two DC motors (this project uses 3v motors)
2x 1kΩ resistors
And one of the below (not needed if you have a 5v motor)
5Ω (or less) resistor with 2w rating or higher
Lots of 100Ω or 50Ω resistors with 1/4w rating (what I used)
Step 1: Hacking the Serial Plug (RS-232)
The first thing to do is hack the USB-Serial adapter. There are nine pins, but you only need three. The way a serial connector works is by sending 5v logic signals to say it’s ready to send or receive a message, along with that message itself. Instead of sending any messages, we’ll just be using those 5v logic pins. The data transmit pin is possible to use, but would require an IC to decode it (like a shift register), or a transistor to amplify the weak current it sends. If you do that, binary ‘0’ is a high voltage on RS-232 and binary ‘1’ is low.
On the serial plug, there is a guard around the pins which you might want to remove to make it easier to solder the pins, but you don’t need to. I was lucky that the pins on the serial plug were hollow. I could clip off the ends and slide a wire inside them which held it in place as I soldered. Solder a wire to the DTR, RTS and ground pins. Solder one to the Transmit Data pin (TD) if you want to play around with that too. Since this part will not get hot when operating the circuit, you can insulate it using a glue gun if need be.
Step 2: The Circuit
Next we need to make the circuit. It is a simple motor bridge connection. The only problem is that TA7291P needs 4.5v to operate, but the motors are 3v. There are two ways to fix this: get higher voltage motors or put in a resistor to limit the current. The resistor would need to be 2 - 5Ω with high wattage (2w or more). However if you bought 1/4 watt resistors in bulk (like I did) you can can put enough in parallel to divide that wattage since eight 1/4 watt resistors can take 2w. Since resistors in parallel divide their resistance, 20 resistors at 100Ω = 5Ω (as would 10 resistors at 50Ω). That is a lot of resistors, but at about $0.02 each, that beats buying an extra 2w resistor. You can see my 100Ω resistor cluster in the photo. You don’t need the switch I’ve put into the circuit, but sometimes the serial pins are set to high when the USB turns on which will make your motor(s) rev before your program can start up and turn them off.
With only one motor bridge, to go forward the robot must ‘waddle’ with each motor being turned on for a few ms before the other is turned on. You could also just get another USB-to-Serial cable and set up another motor bridge for better forward control and power.
Step 3: The Basic (Testing) Program
Now all you need left is the program. I used Python, but it is possible to write it in almost any language. Just Google for how to control a serial port in your preferred language. My program connected to the internet to get commands, but you could also use UDP, TCP/IP, or store the commands in an array. Here is the basic code to test if everything is working. After plugging in your USB device, you have to look in your device manager to see what the connection is called. If you’re in Windows, it will be COM6 or something like that. In Linux, it will be something like /dev/ttyUSB0.
import time
import serial
###initialize the serial connection
#for windows (change COM6 to match the USB device)
#ser = serial.Serial("COM6", 2400)
#for linux (change /dev/ttyUSB0 to match the USB device)
ser = serial.Serial("/dev/ttyUSB0", 2400)
ser.open() #open the connection
#Make sure RTS and DTR are off
ser.setRTS(False)
ser.setDTR(False)
print("initialization finished")
###main loop
c = 1
while c:
ser.setRTS(False)
ser.setDTR(True)
time.sleep(2)
ser.setRTS(True)
ser.setDTR(False)
time.sleep(2)
Step 4: A Sample Program
If you have two motors on one motor bridge, here is sample code for how you can move forward. There are many ways to feed the robot commands like making a list of them or communicating directly with the robot with UDP or TCP/IP. I used an indirect method with AJAX and storing the next command on a web server. Here is a video of my robot moving. The lag in response is because I'm slowly punching in the commands on my webserver (located in Canada) while the robot fetches them (from Japan). The waddle as it moves forward is hardly detectable. It is running without the 5 ohm resistor, and the right and left turns are also operated in pulses so that they aren't too much more powerful than the forward drive. You'll notice the wheels are different in the video because the treads (seen in the other photos) were too weak to support the weight of a laptop reliably. More about the project can be found here.
import time
import serial
ser.setRTS(False)
ser.setDTR(False)
### function to waddle forward (for one motor bridge with two motors)
def move_forward(times):
while times > 0:
ser.setRTS(True)
ser.setDTR(False)
time.sleep(0.2)
ser.setRTS(False)
ser.setDTR(True)
time.sleep(0.2)
times -= 1
###main loop
c = 1
while c:
move_forward(6)
time.sleep(2)
123D Circuits Contest
6 Comments
Question 2 years ago on Step 4
Cool project!! It gives me hope on mine! I am about at wits end on that. I am a computer programmer by trade and not an embedded one. Therefore, I don't have a lot of experience with hardware interfacing. I am attempting to control two steppers (one bi-polar stepper and the other a 2-phase 4 wire) through the RS-232 card that I installed into my PCIE slot (it has two ports). I have determined that I will need a couple max3232 Serial to TTL converters and I am vague on much else. Probably motor drivers and some sort of UART chip or two or four? I need to drive it step by step so that I can keeptrack of where I am and I need to be able to use the micro-stepping of the motor. The serial port out code I believe I have covered if all I need to do is send out characters, but know they need to be interpreted some how on the hardware side. Do you have a direction I can go to get out of my maze? Maybe a suggestion or two? Anything will help.
6 years ago
Product Summary
The TA7291P is a bridge driver with output voltage control.
Parametrics
TA7291P absolute
maximum ratings: (1)Supply voltage, Vcc: 25V; (2)Motor Drive Voltage,
Vs: 25V; (3)Reference voltage, Vref: 25V; (4)Operating temperature,Topr:
-30-75 ℃; (5)Storage temperature, Tstg:-55-150 ℃.
Features
TA7291P features:
(1)4 modes avaliable(CW/CCW/STOP/BRAKE); (2)Output current; (3)Wide
range of operating voltage; (4)Build in thermal shutdown, over current
protector and punch=through current restriction circuit; (5)Stand-by
mode avaliable(STOP MODE); (6)Hysteresis for all inputs.
Diagrams
8 years ago on Introduction
hey dude your on hack-a-day! go take a look!
Woohoo! I get +5 nerd points!
Very interesting.
I suppose that using this method, with some modifications, you could control a step motor, isn't so?
Anything that takes only two logic signals to control would be possible. I assume the data-out plug can be read by a shift register IC, so the sky's the limit!
