Introduction: How to Create DIY Rings
Perfect for beginners.
Step 1: Supplies
The Materials you need to make the Rings are:
- One ring mandrel
- One plier
- Wire with a circumference of 0.9 mm
- Wire with a circumference of 0.5 mm or just a wire that is thinner than 0.9 mm
- 2 bigger beads in any color, in my case purple and yellow
- 4 smaller beads in white
- One wire cutter
Step 2: Find Out Your Ring Size
If you don’t already know your ring size or the ring size of the person you are making the ring for, find that out. To measure your ring size at home you can wrap a string around the base of the intended finger, and then mark where the string overlaps. The length of the string you measured in centimetres is the circumference of your finger.
Step 3: Make the Base of Your Ring
To make the base of your ring wrap the thicker or wire with a circumference of 0.9mm around your ring size on your ring mandrel and cut off the rest of the wire that you don’t need with a wire cutter
Step 4: Round of the Edges
Then use your plier to off round the edges to make them look like a circle.
Step 5: Press Down the Edges
After, doing that your ring may not look round anymore to fix that just put your ring around the ring mandrel, when doing that also press down the ends you just rounded off so they don’t stick out anymore but would lay on your finger when you would wear it.
Step 6: Wrapping the Thinner Wire Around Your Ring
Next, take your thinner or wire with and circumference of about 0.5 mm and wrap that around your ring. Starting at around a quarter away from the loop, so where you rounded of the end, wrapping it toward the end of the ring where the loop is.
Step 7: Add the Beads
After, put the wire through the hole and put the beads on it, first the white smaller bead then the yellow or purple bigger bead, and then the other smaller white bead.
Step 8: Wrapping the Wire Around the Other Side
Then put the wire through the loop again and wrap it around the ring again as you did on the other side, till about a quarter away from the loop
Step 9: Press Down the Ends of the Wire
Next, use your plier to press the ends of the thinner wire to the ring so they won’t hurt you when you are wearing the ring. If your ring is as deformed as mine was just put it on the ring mandrel again and press it down to make it rounder.
Step 10: Do the Same With the Other Rings/Finished Product
Now you are finished with your first ring. At last to the same thing with the rest of the beads, so either with the bigger yellow or bigger purple bead and the two smaller white beads.
