Introduction: How to Create Teleportation Pods in Minecraft
This guide will teach you how to make pods that can teleport you to and from one another in Minecraft.
Step 1: Get the Materials
These are all the materials you will need to create a teleportation pod.
Step 2: Get a Command Block
You can get a command block in minecraft by typing the command /give *your player name here* command_block.
Step 3: Build the Teleportation Pods
You can build the pods however you wish, I just chose the look that appealed to me. The block marked by red on the right is the block we will be teleporting to. The left pod shows the exterior, and the right pod shows the interior.
Step 4: Get the Coordinates
You need to get the coordinates of each of the red blocks. You can find them simply by pressing f3, and looking to the top left of your screen where it should say X,Y, and Z and copy those values down.
Step 5: Type the Command In
Next, type the command in by typing into your command block "tp @p X Y Z". Tp will teleport, @p means that it will teleport the nearest player. Lastly substitute the X,Y, and Z values of the other pod into both command blocks.
Step 6: Step on the Command Block
The last step is to stand on the command block, and watch as it teleports you from one pod to another! :)
