Introduction: How to Create a Lego Living Room Set
These instructions will show you how to create a simple Lego living room set in less than 10 steps.
The size of the pieces needed will be described using "dots." Pieces have various number of dots that form rows and columns. The diagram below shows a 2x4-dot piece. It has 2 columns and 4 rows. Some pieces may have 2x6-dots or 1x4-dots.
Step 1: The Chair
Take two 2x6-dot Lego pieces. Line them up to create a 4x6 base.
Step 2:
Take two 1x4-dot pieces, and place one on top at each 4-dot side, along the edge.
Next take one 2x4-dot piece and place in the center of the top 6-dot edge, between the 1x4 pieces.
Step 3:
Next take one 2x4-dot piece and place in the center of the top 6-dot edge between the 1x4 pieces.
Step 4: The End Table
Stack two 2x2-dot pieces.
Step 5:
Take a flat 4x4 piece, and center it on top of the 2x2 stack.
The end table is complete!
Step 6: The T.V.
To create the look of a T.V., only black and blue legos were used in this model. You may vary the two colors.
Take one black 2x6-dot piece (you may also use two 2x3 pieces to create one 2x6-dot piece).
Step 7:
Take two black 2x1-dot pieces, and place along each 2-dot edge.
Next take one blue 1x4 piece. Place in the center of the bottom 6-dot edge.
Then take one black 1x4 piece and place it in the center of the top 6-dot edge.
Step 8:
Repeat Step 7, using the same colored pieces and in the same positions.
Step 9:
Take one black 2x6-dot piece, and place on top of the last layer (three 2x2 pieces were used to create a 2x6-dot layer).
Optional: Take one red and one green button piece, and place anywhere on the top layer to create ON/OFF buttons for the T.V.
You are now finished with the T.V.!
Step 10: The Finished Living Room Set
Now that you have completed the chair, end table, and T.V., you may use a large, flat base piece (a 16x16-dot piece was used here), and arrange the furniture to create a living room.
Now your little Lego person can sit down and enjoy their favorite Lego T.V. show!
