Introduction: How to Create a Password Protected Folder Without Any Extra Software
There are a lot of methods that you can use to create a password protected folder, most of which require the use of some third party software. Using this neat method you can hide your folders with a quick batch script.
Step 1: Create Your Password Protected Folder
Before you get started you need to create a folder that will house your password protected folder, this is just an ordinary folder and can be located anywhere and named anything.
Step 2:
Navigate into your newly created folder and create a new Text Document. This can easily be done from the context menu.
Open the document, now paste the following code into the contents of the document:
Change the PASSWORD_GOES_HERE text to the password you want to set. Now go ahead and save the file as locker.bat.
Step 3:
Once the file is saved as a batch file you can delete the original text file.
Now run your batch file by double clicking on it–the first time you run it, it will create a folder called Private. This is where you can store all your secret things. When you have finished adding all your stuff to the Private folder, run locker.bat again.
Step 4:
This time you will be asked if you sure that you want to lock the folder, press the “Y” key and hit enter to lock your folder.
Step 5:
You will see that your Private folder quickly disappears.
If you run the script yet again, you will prompted for a password.
If you enter the same password as you set in the script the Private folder will reappear if you enter the incorrect password the script will just Terminate.
Step 6: If You Forget Your Password
Seems like once a week somebody writes in asking how to figure out the password they set. And the answer is really simple: Right-click on the locker.bat file and choose Edit
