Introduction: How to Create an Executable JAR File in Java
In this Instructable ,You will learn how to create an executable jar file using JDK tools.
The Instructable is aimed at beginners who are new to Java
The Code is written in Java and done on a Windows 10 Computer
- We also have a online Tutorial How to Create an Executable JAR File in Java using JDK command line tools
- Source codes can be downloaded from here
This is a software based project so you don't need any supplies. You will have to download a few software's
- Java Development Kit
- Text Editor
Step 1: Creating a Basic Java Jar Executable File
To create an executable JAR file you will have to tell the entry point of the program or which class contains the main() function.
This can be done by the following option.
jar cvfe name-of-your-jar.jar ClassHavingMainFunc Location\your\myclass.class
For example,consider a simple code like HelloWorld.java
public class HelloWorld
public static void main (String[] Args)
System.out.println("HelloWorld");
Place it inside a directory and compile the source code to .class file .
Now create the executable JAR file using the below command
jar cvfe HelloJar.jar HelloWorld HelloWorld.class
You can then run the resulting jar file by
java -jar HelloJar.jar
Now if you unzip the JAR file and view its MANIFEST.MF file
Manifest-Version: 1.0 Created-By: 17.0.2 (GraalVM Community) Main-Class: HelloWorld
