Introduction: How to Create an Origami Tulip
Here is instructions on how to make the flower part of the origami tulip.
Step 1:
Use a square piece of paper (preferably origami paper). If only one side is colored, make sure the colored side is facing down.
Step 2:
Fold the square in half so the two color sides match up on the outside to create a rectangle, then unfold.
Step 3:
Fold it the other way so the other two sides match up to create a rectangle, then unfold.
Step 4:
Now fold the lower left corner to the upper right corner to form a triangle, then unfold.
Step 5:
Fold the lower right corner to the upper left corner to form another triangle, then unfold.
Step 6:
Make sure the colored side is facing up. Now bring the left and right creases to the center and it should collapse into a triangle.
Step 7:
Fold the left corner to the top corner.
Step 8:
Then fold the right corner to the top corner.
Step 9:
Turn the figure over and repeat step 7 by folding the bottom corners to the top corner.
Step 10:
This is where it starts getting a little tricky. Fold ONLY the top two layers of the right side to the left.
Step 11:
Turn the figure over. There should be three layers on the right side. Once again, only fold the top layer of the right side over to the left.
Step 12:
The sides with the pockets should be facing down. Fold the top right and left layer corners into the center to create a kite shape.
Step 13:
Flip the figure over and repeat step 12 to form the kite shape by folding the right and left corners to the center.
Step 14:
Now on one side, insert the right flap all the way into the left pocket.
Step 15:
Turn the figure over and repeat step 14 by inserting the right flap all the way into the left flaps pocket. The bottom should have two holes that look like a bow tie.
Step 16:
With both hands bring the side with the two holes up to your mouth and gently blow. This should puff the tulip out.
Step 17:
Turn the tulip to the top and carefully start to peel the petals down a little above half way. You have just created a beautiful tulip bulb.
