Introduction: How to Crochet Perfect Semi Circle With Single Crochets
Crochet Circles and Crochet semicircle are often used as a foundation for many crocheted projects. The Semi Circle Pattern is the base for making Cute Crochet Rainbow Motifs and Large Crochet Projects like Crochet Rugs, Tablemats, Purses and Shawls. You can also use them as embellishments for the finished Crochet Projects. They are the best to use as Ears for Crochet Hats and many other amigurumi projects.
Today am sharing the pattern for How to Crochet Perfect Semi Circle With Single Crochets. A Semi Circle can be crocheted with Only Double Crochets and Only Single Crochets. The pattern for these both differ from each other. The Double Crochet Stitch being taller than the Single Crochet doesn't require a round of Stitches added between the two Rounds as in case of Single Crochets. Adding this additional round of stitches gives the perfect Semi Circle Shape.
Visit https://rajiscrafthobby.blogspot.com/2024/01/how-to-crochet-perfect-semi-circle-with.html
8 Ply Cotton Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Magic Circle.
Chain 1(Not Counted as a Stitch)
6 Single Crochets.
Pull the yarn end to close the gap and Turn your project.
**(Usually you would Chain 1 and Turn, but in this pattern the absence of Chain 1 creates a neat bottom)
6 Stitches.
Step 3:
Round 2:-
2 Single Crochets in each stitch.
Turn your project to start the next round.
12 Stitches.
Step 4:
Round 3:-
1 Single Crochet in each stitch.
12 Stitches.
Step 5:
Round 4:-
1 Single Crochet.
2 Single Crochets in the next stitch.
Repeat(1SC,2SC)
18 Stitches.
Step 6:
Round 5:-
18 Stitches.
Step 7:
Round 6:-
1 Single Crochet each in 2 stitches
Repeat((1SC*2),2SC)
24 Stitches.
Step 8:
Round 7:-
24 Stitches.
Step 9:
Round 8:-
1 Single Crochet each in 3 stitches
Repeat((1SC*3),2SC)
30 Stitches.
Step 10:
Round 9:-
30 Stitches.
Step 11:
Round 10:-
1 Single Crochet each in 4 stitches
Repeat((1SC*4),2SC)
36 Stitches.
Step 12:
Round 11:-
Once you reach the end weave off the yarn.
36 Stitches.
If You Wish To Make It Larger, then Keep repeating the increase pattern untill the size needed.
The increase pattern will be as below:-
Round 12 - (1 DC*5, 2 DC) - 42
Round 13 - (1SC in each St)- 42
Round 14 - (1 DC*6, 2 DC) - 48
Round 15 - (1SC in each St) - 48
Round 16- (1 DC*7, 2 DC) - 54
Round 17 - (1SC in each St) - 54..... and so on !!!!
