Introduction: How to Crochet a Easy Knit Like Infinity Scarf
About: Hello all!!!! A warm Welcome and It's a pleasure to have you here. Art and Craft is my passion .I love experimenting new and creative ideas.
I love the versality that a Crochet Stitch carries. Even with a simple change or a twist you can create beautiful textured stitches. Just change the way you are holding your hook or just change the working loop and you end up with a new stitch.
Today am sharing the tutorial for How To Crochet A Easy Knit Like Infinity Scarf . Crochet Infinity Scarves are the best to keep you warm. Unlike the normal scarf , the crochet infinity scarves are worked in a closed circle with no loose ends. You can either make them in continuous rounds or you can crochet a long rectangle and join the ends.
The pattern is very easy made with only Half Double Crochets. The only twist is that the stitches are made only in the Third Loops. This creates a lovely Knit Like textured finish.
Visit https://rajiscrafthobby.blogspot.com/2024/08/how-to-crochet-easy-knit-like-infinity.html
8 Ply Cake Yarn
5.50 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 140 or else , you can Start with any Even number of Chains untill its around 60 inches in size.
Quick Tip to Stop the Chain from Twisting:-
  1. Chain the first 8 to 10 stitches.
  2. Remove the hook from your work and insert it into the first chain.
  3. Now , be careful and without twisting the chains, insert your hook into the working loop.
  4. This way the first chain on the hook will be just behind the current working loop.
  5. Once you are done with the required number of Chains, pull the yarn through the first loop.
  6. This will ensure smooth untwisted Chains.
Step 3:
Round 2:-
Chain 2.(not counted as a stitch)
1 Half Double Crochet in the same stitch.
1 Half Double Crochet each in the remaining stitches.
Once you reach the end, do not slip Slip stitch. We will be working in continuous rounds.
Step 4:
Round 3:-
**This round onwards , we will be making the stitches into the Third Back Loop of the stitch - i.e. Count the Stitches from the Front - Front Loop , Back Loop and the loop in the Back of the Back Loop is the Third Loop.
1 Half Double Crochet in each of the Third Loops.
Once you reach the end , do not make a Slip Stitch , we will be working in continuous rounds.
Step 5:
Round 4:-
Keep repeating Round 3 untill its around 5 to 6 inches in size.
Make a Slip Stitch into the next Stitch and Weave off.
