Introduction: How to Crochet a Bag
Here is our take on the famous Hudson's Bay Blanket, which we made for Canada Day 2015. It's one of those simple designs that no matter what rendition you make, it always looks good.
MATERIALS YOU'LL NEED:
- 5 skeins of DK weight cotton yarn (1 blue, 1 yellow, 1 red, 1 green, 1 off white). We used DROPS Design Muskat (50g/100m per ball)
- 3.75 mm hook
- Sewing needle & off white thread
- Purse chain
ABBREVIATIONS: (US Terminology)
sc = single crochet st (s) = stitch (es)
TECHNIQUES:
You’ll need to know how to crochet in the round and change colors. The entire bag is made using a single crochet stitch. If you’re new to crochet, Wool and the Gang has great tutorials for beginners.
PATTERN:
Note: Every color change is worked for 3 rows (except for the initial row)
- 4 rows in off white
- 3 rows in blue
- 3 rows in off white
- 3 rows in yellow
- 3 rows in red
- 3 rows in green
Step 1: Make the Foundation Chain
Chain 75 in the off-white colored yarn, joining the ring with a sc. This is the foundation row for the bag.
Step 2: Work 4 Rows
Work 4 rows in sc, using the off-white color.
TIP: Refer to the step 2 image above for a tip on how to identify a new row at the end of each round.
Step 3: Change to Blue
At the end of the last stitch from the 4th row, change to blue yarn.
Step 4: Work 3 Rows in Blue
TIP: Once you start changing colors, you'll notice that the last row looks higher than the next. DON'T WORRY, it looks like that because you're crocheting in the round. Once you sew the bottom of bag at the end, those rows will be on the corners of each bag and won't be as noticeable.
Step 5: Repeat Step 4 for Each Color
After you’ve completed 3 rows in blue, change back to off-white to work for another 3 rows. Continue with the pattern by changing colors every three rows, until you’ve reached the end of row 3 in green.
Step 6: Make a Chain Space
Crochet 2 rows in off-white, until you’ve reached the last 4 stitches in the 2nd row. Here is where you’ll be making a chain space for the purse handle [ *sc 1 st, chain 2, sc 1 st*, sc 36 sts, repeat between * * ]
Continue with the sc across to the first chain space. Once you’ve reached the chain 2 space, sc 2 stitches in the chain space made to reinforce the stitch. Crochet around to the end of the row, and finish with a slip stitch.
Step 7: Sew the Bottom Closed
Turn the bag inside out, using the two chain spaces as your guide for how to line up the edges. Sew in the bottom using the off white colored yarn.
