Introduction: How to Curl Your Hair
If you have ever needed to curl your hair and don't know how to, here are 10 easy steps for an easy and simple hairstyle.
Step 1: Gather Your Supplies
Supplies you will need include any brand curling wand, hair brush, clip or hair tie, hairspray, and heat protectant spray.
Step 2: Heat Up Your Curling Iron
Heating up your curling iron can take at least 2 minutes so do this before starting the process. Depending on how thick your hair is, temperature may vary.
Step 3: Brush Out Your Hair
Brushing out your hair before starting can help you section your hair easier and give you smoother curls.
Step 4: Spray Your Heat Protectant
Heat protectant helps to seal the moisture in your hair and avoid frizz. It also prevents split ends, dryness, and serious breakage.
Step 5: Put Up Your Hair
Section half of your hair from the rest of the head and put it up in a bun with a clip or hair tie. This will help will help keep the rest of your hair out of the way and ensure you get your whole head of hair curled.
Step 6: Curl Your Hair
Wrap your hair around the wand curling away from your face. This will create a more natural wavy look.
Step 7: Scrunch Your Hair
After you take the curl off the wand, scrunch up the curl until it dries. This will leave a tighter curl that will last longer.
Step 8: Repeat Curling and Scrunching Your Hair
Repeat curling and scrunching your hair until you have finished your whole head.
Step 9: Spray Your Hairspray
Spray your finished hairstyle with a layer of hairspray so the curls stay in longer.
Step 10: Run Your Fingers Through Your Hair
Once the hair has fully cooled down, go ahead and run your fingers through it for a more loose and natural look.
Step 11: Conclusion
Now that you know the basic steps to curling your hair, you can go try this on yourself and on your friends.
