How to Cut a Light Bulb in Half
Intro: How to Cut a Light Bulb in Half
In this Instructable, we'll have a look at one of the ways to cut light bulbs in half.
Once the bulb is cut in half, you can put in a large object and glue the bulb back together.
We will need:
- Empy/Hollow Bulb
- Nichrome Wire
- Copper Foil Adhesive Tape
- Battery from a drill or alternative power source
If you are Interested in a video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
STEP 1: Put a Nichrome Wire Onto the Bulb
Take a piece of nichrome wire, twist it to make a loop.
Slide it onto the bulb.
It should fit tightly.
STEP 2: Secure the Wire With a Copper Tape
Secure the wire to the bulb with a copper tape.
Put 2 pieces of tape on each side of the wire twist.
STEP 3: Separate the Wire Twist
Cut off the twist and separate the wire.
STEP 4: Prepare Your Power Source
Prepare your power source.
I used a battery from a drill.
It's a 24v battery, but lower voltage batteries should also work.
As long as the battery has lots of amps, it should work.
Most of the power tool batteries will be powerful enough.
The power source will also depend on the nichrome wire you use.
Thinner the wire, less powerful battery you will need.
STEP 5: Cut the Bulb
Put the positive cable to one end of the wire and the negative cable to another end of the wire.
The wire will start to glow.
Be careful as it will become extremely hot
If the wire does not light up in 2-3 seconds, your battery might not be powerful enough.
If the wire burns out, that means you have too much power.
After a few second of heat, the bulb will split in half.
Don't worry if there is a piece of glass that is uncut (the part where the wire did not touch).
It will break once you try to separate the glass.
STEP 6: What's Next?
With a bulb cut in half, you can make something cool.
I put a large pad-lock in the bulb and glued the bulb back together.
If you look closer, the line is visible, but it still looks impressive.
If you want to hide the cutting line, you can try to use a window color to draw something on top.
75 Comments
emsuemac 4 years ago
sveedio 7 years ago
Dawsie 7 years ago
that's so cool :-) as for glue there is a glue that you can get for fixing wine glass and that sort of thing I used years ago to fix a set of wine glasses and you could not tell where I had fixed them :-) you can get the glue from a good hardware store in the section the gave for all their glues :-) that's where I bought mine years ago :-)
Will gave to buy some of those bulbs to try the trick :-) love it and if I make a special stand for it to sit in I could hide the glued line behind the stands ring for holding the bulb :-)
Thanks for a great idea :-)
xenobiologista 8 years ago
Where can you buy or easily scavenge nichrome wire from?
Laral 7 years ago
I was wondering the same thing. eBay has it at good prices - nichrome wire | eBay. If you're willing to wait, this guy - Nichrome Wire 32 Gauge 0 2mm KANTHALA1 Cantal 100 ft Resistance Resistor AWG | eBay - is selling 100ft of 32GA for $1.96 from China.
Peterd92 7 years ago
I found it on Amazon.com.
Angelbane 7 years ago
You can buy it from vape stores as they use it in the homemade vaping equipment.
smurfi1989 8 years ago
Think you can try guitar cord as well but try a thin gauge cord to start off with. Used this in a foam cutter they heat up nice.
lithiumdaze 8 years ago
Nokota 7 years ago
Seriously, what kind of glue did you use? The line is barely visible and the whole thing looks better without the glass paint, personally, I think. This whole instructable is useless if you don't tell us what kind of glue you used to make such a seamless and strong bond when putting the glass back together. Several people have already asked.
fauxgal 7 years ago
Laral 7 years ago
I use E6000 and it is great, but it is way too viscous for this purpose. Regular viscosity cyanoacrylate glue (Superglue) would be best. It flows really well. You could apply it with a pin or toothpick.
Calcfan 7 years ago
The bulb could also be cut diagonally to be slightly less obvious. Calcfan.
This looks way cool and i want to try it. What gauge is the nichrome wire? I see it comes in a variety of gauges (20g, 24g, 26, 36g, and probably others).
Other than that question, this was an excellent video!
arekaybee 8 years ago
Would this process work to make a hole in the bulb?
EmillyBint 8 years ago
Nice idea. I also love these two ideas. Do you have an idea how to cut the metal part?
JayLundgren 8 years ago
Emilly, you can cut the metal part with a Dremel tool and a cutting disc.
akshayamytaneja 8 years ago
This is a really nice idea!
JoyM10 8 years ago
Emily, you should do an instructible segment on this idea.
