Introduction: How to Cut a Mango Without Waste
The unique shape and large seed of a mango can be a bit frustating. However, it's totally possible to cut a mango without wasting a piece!
Read full guide about how to cut a mango
Materials
- Mango
Tools
- A medium sharp knife
- A cutting board
Step 1: Wash and Dry
Begin by washing the mango under cool running water to remove any dirt or residue. Pat it dry with a clean towel.
Step 2: Peel Off the Skin
Gently peel off the skin of the mango. Try to peel it off without taking away too much mango flesh. Also cut the small stem at one end.
Step 3: Cut 2 Largest Pieces
The mango seed is flat and oval-shaped. Slide your knife gently from the stem and cut downwards following the curve of the seed. The goal is to cut as close to the seed as possible without hitting it, to get 2 largest pieces (mango cheeks) in front and back of the seed lengthwise.
Step 4: Cut 2 Other Pieces on the Side
Continue to follow the curve of the seed and cut off 2 other pieces on 2 sides. Below is what we've got after this step.
Step 5: Trim Remaining Flesh
After removing the majority of the mango flesh, carefully cut off any remaining flesh around the seed. You can either use a knife or simply use your teeth to enjoy this delicious treat.
