Introduction: How to Cut a Perfect Circle the Easy Way
This is my first Instructables project. I'm really using it as a test of the submission process. Apparently you can write a lot here
See below for a list of required supplies:
- piece of paper
- sharpened pencil
- pair of scissors
- a can of emergency drinking water
- a calculator - just kiddling! You don't need a calculator. This is the easy method.
Step 1: Drawing the Circle
Place your emergency can of water on the paper and trace with your sharpened pencil. Easy peasy. Check out the nifty video.
Step 2: Remove the Can O Water
That's all you have to do. See the perfect circle that you've drawn.
Step 3: Time to Cut
Work those scissors. All you have to do is follow the line you made in the earlier step.
Be careful now! Don't cut yourself.
Step 4: Look, Mom! All Done.
That's all it takes. Now you have a perfect circle. With a little practice you could be cranking two or more of these out a minute! Think of the possibilities.
Some suggestions for making this project your own:
- Try colored paper!
- Try different size circles. Just find something bigger or smaller to trace!
- Try some different shaped objects. Let your imagination go wild!
