Introduction: How to Cut a Pomegranate
About: “Keep Up Cooking” is founded to share all the recipes which have less sugar, less unhealthy fat and more fresh & natural ingredients. Besides, this is also the place to share my experiences in cooking & prepar…
The challenge lies in their tough outer skin and numerous seeds, making them a bit tricky to cut.
Reference: how to cut a pomegranate
Tools
  • A Knife: Opt for a thin-blade knife with the length of 15-17 cm (5-7 inches).
  • A container: Prepare a medium container to catch the seeds after being removed from the fruit.
Step 1: Score the Pomegranate and Break Apart
  • Use a knife to carefully slice off the crown (the top portion of the pomegranate where the stem is attached). This will create a flat surface to work with.
  • Observe the pomegranate to figure out the the concave and convex parts of it. Hold the pomegranate with one hand, and with the other, make a shallow cut on a concave part of the fruit (image below).
  • Gently pull the pomegranate apart along the scored lines. The sections should separate easily, revealing the clusters of seeds inside.
Step 2: Break the Halves Into Smaller Parts
To break the halves into smaller pieces to reveal all the seeds, there are 2 methods:
  • Method 1. Continue to make shallow cuts on concave parts, then gently break them.
  • Method 2: Make a small cut on the outer skin and tear the skin off and break the halves into smaller prts.
Step 3: Remove Seeds
Use your fingers to gently remove each bunch of seeds from the white membrane that surrounds them.
The seeds will drop directly to the container you prepare.
