Introduction: How to Design Vent Patterns for Your 3D Printing Projects
About: Tech Educator | Content Creator | Developer | Maker - Simplifying technology through hands-on learning. Creating high-quality tutorials, projects, and insights on electronics, IoT, robotics, CAD, 3D printing, …
In this article, I’ll guide you through transforming simple 3D-printed projects into visually stunning creations by incorporating custom vent patterns. To demonstrate, I’ll be using a 5050 fan and designing nine unique vent patterns for it, each with its own style and structure. Vent designs are a fantastic way to add both functionality and aesthetic appeal, turning a basic fan cover or similar project into something eye-catching and unique. By using the powerful pattern tools in Fusion 360, you can easily replicate shapes, create symmetry, and bring professional polish to your designs. This step-by-step guide is perfect for students and beginners who want to explore how small design elements can elevate their 3D prints. Let’s dive into creating patterns that make your projects stand out!
Step 1: All the Pattern Tools in Fusion 360
In Fusion 360, both 2D and 3D patterning tools allow you to create rectangular and circular patterns, offering flexibility whether you’re working in a sketch or directly on 3D features. Here’s how each type works and how it can be applied:
2D Patterns
2D pattern tools are used in the sketch environment, where you can repeat shapes directly on the drawing plane before extruding them into 3D objects. This is ideal for creating vent designs with precise control over spacing and placement.
  1. 2D Rectangular Pattern
  2. The 2D rectangular pattern lets you repeat a shape or sketch element (like a circle or rectangle) across the X and Y axes within the same sketch.
  3. You can specify the number of copies and the spacing between them, making it easy to create a grid of shapes for vent designs or other repetitive elements.
  4. This tool is useful for creating evenly spaced rows and columns of holes, grids, or textures directly on the sketch plane.
  5. 2D Circular Pattern
  6. The 2D circular pattern tool allows you to copy a shape (or multiple shapes) around a central point within the sketch.
  7. This is ideal for creating radially symmetric designs, such as fan covers, circular vents, or decorative patterns.
  8. You can set the number of instances and the angle of distribution, giving you control over the symmetry and density of the pattern.
3D Patterns
3D pattern tools take things a step further by applying patterns to extruded or modeled features, allowing you to repeat parts of your model along linear or radial paths directly in 3D space.
  1. 3D Rectangular Pattern
  2. In 3D mode, the rectangular pattern allows you to repeat a selected feature, body, or component across X, Y, and optionally Z axes.
  3. This is particularly useful for creating arrays of extruded shapes or features across the surface of a part.
  4. You can control spacing, direction, and number of copies, which is helpful for creating vented panels or surfaces with repeating textures in multiple dimensions.
  5. 3D Circular Pattern
  6. The 3D circular pattern tool repeats a feature, body, or component in a circular layout around an axis you select.
  7. This is useful for creating elements like holes, spokes, or decorative features that need to be spaced around a central point.
  8. This tool is versatile for projects like fan covers, where vent holes can be arranged in a circle to promote airflow, or for any design that requires radial symmetry in 3D.
Fan Went
Step 2: Creating a Rectangular Pattern Vent
Create the Base Plate:
  1. Start by sketching a basic 1.5mm thick plate with dimensions of 50x50 mm to match the size of the 5050 fan.
  2. Add 3mm corner fillets on all four corners to smooth them out.
  3. Draw 4mm holes aligned with the fan’s mounting points, ensuring they line up perfectly with the fan holes.
  4. Use the Press Pull tool to extrude (pull) the plate to a thickness of 1.5mm.
  5. Make the 9 copies of base plate using Move & Copy tool.
Draw the Patterned Area:
  1. On the base plate, draw a 44mm radius circle at the center to outline the vented area.
  2. Inside this circle, create a 4x4 mm square that will serve as the repeating shape for the vent pattern.
Create the Rectangular Pattern:
  1. Select the square, and using the Rectangular Pattern tool in drawing mode, set X = 9 and Y = 9 with 1mm spacing between each square.
  2. This will replicate the square in a grid pattern across the circle, creating a balanced rectangular mesh.
Finalize the Pattern:
  1. After completing the sketch, choose the squares that fall within the circular outline to create the vented pattern.
  2. Use the Press Pull tool with a -2mm depth to cut these selected squares out, forming the vent holes.
With this method, you’ve now created a rectangular mesh using the rectangular pattern tool, giving your fan cover a clean, grid-like vent pattern.
Step 3: Creating a Circular Pattern Vent
Define the Vent Area:
  1. Begin by sketching a 44mm diameter circle at the center of the base plate to outline the vented area.
Draw Concentric Circles:
  1. Starting from the top of the vent area, draw a series of five concentric circles with diameters of 5mm, 4mm, 3mm, 2mm, and 1mm.
  2. Space each circle 2mm apart to create a cascading effect from the center outwards.
Apply the Circular Pattern:
  1. Select the five circles and use the Circular Pattern tool to replicate them around the center of the 44mm circle.
  2. Set the pattern to 18 instances around the circle’s center, creating a balanced radial array of circles within the vent area.
Finalize the Vent Holes:
  1. Once the pattern is complete, select each of the circles in the pattern and use the Press Pull tool with a -2mm depth to cut out the vent holes.
Step 4: Creating a Honeycomb Pattern Vent
Outline the Vent Area:
  1. Start by drawing a 44mm diameter circle at the center of the base plate to mark the boundary of the vented area.
Create the Hexagon:
  1. In the center of the vent area, sketch a 4mm hexagon. This hexagon will serve as the base shape for the honeycomb pattern.
Replicate the Hexagon with the Rectangular Pattern Tool:
  1. Use the Rectangular Pattern tool to replicate the hexagon across the circle area.
  2. Set the pattern with enough rows and columns to cover the entire circle, keeping a small gap between each hexagon to maintain a uniform honeycomb structure.
  3. This creates a repeating hexagonal grid that fills the vent area with a honeycomb effect.
Finalize the Pattern by Cutting the Holes:
  1. After completing the pattern, select all hexagons within the circle boundary.
  2. Use the Press Pull tool with a -2mm depth to cut out each hexagon, forming the honeycomb vent holes.
Step 5: Creating a Slot Pattern Vent
Inside the outline:
Draw the Slot:
  1. Start by drawing a slot with dimensions of 4mm(2mm) width and 8mm(4mm) length centered in the vent area.
Create the Slot Pattern:
  1. Use the Rectangular Pattern tool to replicate the slot across the area, setting the X and Y values to achieve a grid layout with evenly spaced slots.
Cut Out the Slots:
  1. After finalizing the pattern, select the slots within the outline and use the Press Pull tool with a -2mm depth to cut them out, forming the vent holes.
Step 6: Uniform Circle Pattern Went
Draw the Circle:
  1. Begin by drawing a 4mm diameter circle at the center of the vent area.
Create the Circle Pattern:
  1. Use the Rectangular Pattern tool to replicate the 4mm circle across the area, setting the X and Y values to create a grid of evenly spaced circles.
Cut Out the Circles:
  1. After completing the pattern, select the circles within the outline and use the Press Pull tool with a -2mm depth to cut them out, forming the vent holes.
Step 7: Creating an Angled Slot Pattern Vent
Draw the Angled Slot:
  1. Start by sketching a slot with dimensions of 4mm width and 8mm length, positioned at a 45-degree angle.
Apply the Rectangular Pattern in 3D Mode:
  1. Instead of using the rectangular pattern tool in drawing mode, create the first slot cut using the Press Pull tool with a -2mm depth.
  2. Then, select the cut feature and use the Rectangular Pattern tool in 3D mode to replicate the cut along the X and Y axes, creating a grid of angled slots.
Step 8: Creating a Line Pattern Vent
Draw the Rectangle and Center Circle:
  1. Sketch a 45x2mm rectangle centered in the vent area.
  2. Draw a 10mm circle at the center of the rectangle.
Create the First Cut and Pull:
  1. Use the Press Pull tool to cut out the outline circle to a depth of -2mm.
  2. Leave the center circle intact, and use the Press Pull tool to extrude the rectangle up to 1.5mm.
Replicate the Extrusion:
  1. Select the rectangle extrusion and use the Rectangular Pattern tool to replicate the pull feature across the area.
Step 9: Center Slot Went
Draw the Slots:
  1. Begin by sketching four slots: one linear slot and three concentric slots of varying sizes, centered in the vent area.
Create the Initial Cut:
  1. Use the Press Pull tool to cut out the slots to a depth of -2mm, forming the initial vent design.
Replicate with Circular Pattern:
  1. Select the cut feature and use the Circular Pattern tool in 3D mode to replicate the slot design four times around the center of the vent area, creating a circular arrangement of slots.
Step 10: Aperture Went
Draw the Outer and Inner Circles:
  1. Start by sketching a 44mm outer circle and a 10mm inner circle at the center of the vent area.
  1. Between the outer and inner circles, draw a 45-degree angled slot positioned slightly off-center to resemble an aperture blade.
Create the Cut and Extrude Features:
  1. Use the Press Pull tool to cut out the area inside the outer circle to a depth of -2mm.
  2. Select the slot and inner circle, then use Press Pull to extrude these features up to 1.5mm, creating a raised slot design.
  1. Select the extruded slot and replicate it using the Circular Pattern tool around the center point, setting it to 8 instances to complete the aperture-like effect.
Step 11: Conclusion
I hope this guide has shown you how easy and rewarding it can be to enhance your 3D printed projects with creative vent patterns. These designs not only improve functionality but also add a unique aesthetic to your work. I've used these vent patterns across many of my own 3D printed projects, which you can check out on my Instructables profile.
If you enjoyed this article, don’t forget to hit the like button and leave a comment below. And if you've tried creating your own designs or adapted them to a camera slider or other projects, be sure to share your experience in the "I Made It" section.
Thank you for following along, see you next time ;)
