Introduction: How to Design a Maze Puzzle
Step by step process on how to design and 3D print a Ball Maze.
(Eaglebrook School)
Download / Purchase Fusion 360
Step 1:
Enter Fusion 360 and then select new plain.
Step 2:
Press create and then select 2-Point Rectangle.
Step 3:
Make a 150mmx150mm square
Step 4:
Press E to extrude the square. Then extrude it 5mm.
Step 5:
After making your 3d sqaure select 2-point rectangle.
Step 6:
Make a 5mm x 150mm rectangle of the edge of the square.
Step 7:
After making your Rectangle press E and then extrude it 10 mm.
Step 8:
Repeat step 6 and 7 until you get a shape like this.
Step 9:
Use the 2-Point rectangle to create all of the obstacles in your maze.
Step 10:
After Creating all of your obstacle's. Press e to extrude and hold shift to select all of your obstacles. This will allow you to extrude all of them at once. Extrude the obstacle's 10 mm.
Step 11:
After extruding your maze should look something like this.
Step 12:
Next select create and then sphere.
Step 13:
Make the sphere 7.5mm in diameter.
Step 14:
Make a Start and finish in your Maze by selecting create and then center diameter circle.
Step 15:
Put your circles where you would like your start and finish to be.
Step 16:
Lastly extrude your circles -2mm
Step 17:
The Last step is to 3D print your Maze.
Step 18:
Finished Product
