Introduction: How to Design a Starbucks Coffee Cup Using 3D CAD Software
Learn How to Design a Starbucks Coffee Cup Using 3D CAD Software with the help of this article
Step 1:
Starbucks is known for its iconic coffee cups, which blend functionality with an appealing aesthetic. Designing a Starbucks coffee cup using SelfCAD, a powerful and user-friendly 3D modeling software, allows designers to create customized cup designs with precision and creativity. This article will guide you through the step-by-step process of crafting a Starbucks coffee cup in SelfCAD, covering essential tools, modeling techniques, and customization options. Whether for personal projects, branding exercises, or prototyping, mastering this process offers valuable insights into digital design and 3D modeling
To access the interactive tutorial to this article, check out; https://www.selfcad.com/tutorials/1c4u4a26323s53o5a20363p2z142x3h2h421
Once you’ve launched the editor;
From the 3D Shapes category on the toolbar choose cylinder; Set Bottom radius to 40, height to 135, horizontal segments to 4, vertical segments to 128
Tick the checkmark to finalize cylinder
Click to activate polygon selection; Click on highlighted region to select it
Click delete button to delete selected objects
From the modify category on the toolbar choose inset; Set inset amount to 3.
Tick the checkmark to finalize inset
Click move on the toolbar; Set y to 4
Click ‘x’ to close transformation panel
Click move on the toolbar; Set y to 6
Click on highlighted region to deselect it
From the modify category on the toolbar choose add thickness; Set thickness to 1.
Tick the checkmark to finalize add thickness
From the 3D Shapes category on the toolbar choose cylinder; Set height to 10, vertical segments to 128, position y to 136
Click highlighted part on selection cube to turn off region selection
Click isolate button to isolate selected objects; Click to activate polygon selection, click on highlighted region to select it
Click move on the toolbar; Set y to 155
From the modify category on the toolbar choose inset; Set inset amount to 5.
From the modify category on the toolbar choose extrusion.
Tick the checkmark to finalize extrusion
Click rotate on the toolbar; Set x to 357
Click to activate edge selection
From the modify category on the toolbar choose fillet; Set intensity to 1.4, level to 5.
Tick the checkmark to finalize fillet
Click show button to show mesh 4
From the modify category on the toolbar choose add thickness; Set thickness to 1, use mirrored thickness to true
From the 3D Shapes category on the toolbar choose cube; Set width to 10, height to 10, depth to 4, position y to 155, position z to 35
Tick the checkmark finalize cube
Click on mesh 8 to select it
Click stitch & scoop on the toolbar; from the tool panel choose difference, Choose mesh 12 to subtract.
Tick the checkmark to finalize difference
Click color picker button to change color of object; Click black.
Click ok
Click solid+wireframe button to set rendering mode
Click on mesh 4 to select it. Click on difference 1 to deselect
Click to activate face selection, click on the gear icon to open advanced selection tools, set loop selection to true
Click on highlighted face to select loop from the object
From the modify category on the toolbar choose extrusion; Set use vertex normals to true, extrusion amount to 1
Click color picker button to change color of object; click brown
Click ok
Click inverse selection button to inverse selection
Click color picker button to change color of object; Click white
Click ok
Click solid button to set rendering mode
As you continue honing your design skills, remember that SelfCAD offers a wealth of resources to support your learning journey. To deepen your understanding and explore more advanced features, consider checking out the interactive tutorials (https://www.selfcad.com/tutorials) available on the SelfCAD website. The tutorials page provides a treasure trove of guides, tips, and tricks that cater to designers of all levels.
More structured learning experience can also be accessed at the SelfCAD Academy (https://www.selfcad.com/academy/curriculum/), https://www.youtube.com/@3dmodeling101, and 3D Modeling 101 series (https://www.youtube.com/playlist?list=PL74nFNT8yS9DcE1UlUUdiR1wFGv9DDfTB). This comprehensive resource offers in-depth courses taught by industry experts, allowing you to master the intricacies of SelfCAD at your own pace
