Introduction: How to Design a Wrapping Paper Cutter Using 3D CAD Software
Learn How to Design a Wrapping Paper Cutter using 3D CAD Software with the help of this article
Step 1:
Cutting wrapping paper can be unexpectedly tricky. Uneven edges, torn sheets, and wasted material often turn a simple task into a frustrating one. A well-designed wrapping paper cutter can eliminate these problems by providing a smooth, guided cutting experience. Instead of relying on mass-produced tools that may not fit your exact needs, designing your own cutter allows you to tailor it to the size of your rolls, your cutting preferences, and your workspace.
In this article, you’ll learn how to design a functional and easy-to-use wrapping paper cutter using SelfCAD, an intuitive, browser-based 3D modeling application. SelfCAD is perfect for beginners and intermediate users alike, combining powerful design tools with a simplified interface. We’ll go step-by-step through the design process, from planning the structure and measuring dimensions to modeling each component; so you’ll gain both a practical tool and valuable 3D design skills. By the end, you’ll have a custom cutter that can be 3D printed and put straight to use.
To access the interactive tutorial to this article, check out; https://www.selfcad.com/tutorials/6z38393i15n3u2xi2z726n426o4427123k5q
Once you’ve launched the editor;
From the 3D Shapes Category on the Toolbar choose Cylinder; Set Height to 200, Horizontal Segments to 7, Vertical Segments to 29
Click to finalize Cylinder
Click to activate Face Selection; Click on highlighted region to select it
Click Delete button to delete selected object
From the Modify Category on the Toolbar choose Add Thickness.
Click to finalize Add Thickness
Click to activate Edge Selection; Click on highlighted region to select it
Click Move on the Toolbar; Set y to 129.29 using highlighted gizmo
Click ‘x’ to close Transformation panel
As you continue honing your design skills, remember that SelfCAD offers a wealth of resources to support your learning journey. To deepen your understanding and explore more advanced features, consider checking out the interactive tutorials (https://www.selfcad.com/tutorials) available on the SelfCAD website. The tutorials page provides a treasure trove of guides, tips, and tricks that cater to designers of all levels.
More structured learning experience can also be accessed at the SelfCAD Academy (https://www.selfcad.com/academy/curriculum/), https://www.youtube.com/@3dmodeling101, and 3D Modeling 101 series (https://www.youtube.com/playlist?list=PL74nFNT8yS9DcE1UlUUdiR1wFGv9DDfTB). This comprehensive resource offers in-depth courses taught by industry experts, allowing you to master the intricacies of SelfCAD at your own pace.
