Introduction: How to Design an Acoustic Guitar in Fusion 360 Using a Parametric Modeling Project - & Bass / Ukulele
In this project we will design a custom acoustic guitar by adjusting the 111 available parameters in this guitar project for Fusion 360, a free CAD program which is an industry standard software for designing objects to be fabricated.
Step 1: Opening File
After downloading the free version here from Instructables or the full version available on my website loriancapos.com/guitar we need to open it and save it into our Fusion drive.
  1. Go to file, Open..., On the folder window that has been just opened click: Open From My Computer...
  2. Locate the file and open it.
  3. Then save it into a new project called "Guitar" or any other name for your project. The original file will remain untouched and all changes will take place into your own version of the file.
  4. Learn to navigate Fusion with your mouse if you don't know it already. (Shift + Middle Mouse Button to Orbit, MMB again alone to Pan, and scroll wheel to dolly back and forth)
Step 2: Parameters Window
After opening you will see the guitar design on your Fusion workspace. Now time to edit the parameters to customize it.
  1. Go to modify, (Under Design workspace, "Solid" tab), select the "Change Parameters" item almost all the way at the bottom.
  2. Parameter windows should be opened now. Sort names alphabetically to organize them as they are not in order by default.
  3. Here you are free to change any parameter to suit your vision. Here is a list of all parameters available.
Parameters:
BodyBackRadius
BodyScaleInInches
BodySideDepthOnBottom
BodyTopRadius
BridgeHeightBassSide
BridgeHeightTrebleSide
BridgeLength
BridgeLowerSectionLength
BridgePinAngle
BridgePinCount
BridgePinDistanceFromSaddle
BridgePinHoleDiameter
BridgePinSetCount
BridgePinTotalSpaceDistance
BridgeRadius
BridgeSideEdgeThickness
BridgeWidth
BridgeZOffset
ClassicalBridgeLength
ClassicalBridgeWidth
ClassicalBridgeZOffset
ClassicalPegHoleDepth
ClassicalPegHoleInnerDiameter
ClassicalPegHoleOuterDiameter
ClassicalPegHoleSpacing
ClassicalPegSlotDistanceFromEdge
ClassicalPegSlotDistanceFromHeadstockEnd
ClassicalPegSlotLength
ClassicalPegSlotWidth
ClassicalStringHoleDiameter
ClassicalStringHoleTotalSpacing
CutawayEdgeDistanceFromNeck
DoubleBridgePinDiagonalOffset
DoubleBridgePinDistanceFromSaddle
DoubleBridgePinOffsetAngle
Fretboard12thFretPositionOffset
FretboardGapFromSoundHole
FretboardNutWidth
FretboardRadiusAtNut
FretboardRadiusAtSaddleTheory
FretboardSinkInDepth
FretboardStringScaleLength
FretboardThicknessAtNut
FretboardThicknessAtSaddleTheory
FretboardWidthAt12thFret
FretSlotDepth
FretSlotWidth
FretZShiftUniform
HeadstockAngle
HeadstockHeightOffset
HeadstockLength
HeadstockOffsetDistanceFromNeck
HeadstockThickness
HeadstockVeneerThickness
HeadstockWidthAtEnd
HeadstockWidthNearNut
HeelCurveAngle
HeelFlushness
HeelLength
HeelNeckCurveStartDistanceFromBody
HeelShapeSides
HeelShapeTip
HeelWidth
NeckAngleCompensation
NeckJointAngle
NeckJointBlockChamfer
NeckJointBlockDepth
NeckJointBlockHoleDiameter
NeckJointBlockHoleDistanceFromTop
NeckJointBlockHoleSpacing
NeckJointBlockWidth
NeckJointDepth
NeckJointHoleDiameter
NeckJointLength
NeckJointWidthAtBase
NeckShapeAtHeelCurve_Center
NeckShapeAtHeelCurve_Edge
NeckShapeAtNut_Center
NeckShapeAtNut_Edge
NeckThicknessAtHeelCurve
NeckThicknessAtNut
NutHeightOffsetFromFretboard
NutRadius
NutSinkDepth
NutThickness
PanelBackSoundboardThickness
PanelSideSoundboardThickness
PanelTopSoundboardThickness
PegHoleCountBass
PegHoleCountTreble
PegHoleDiameter
PegHoleDistanceFromEndOfHeadstock
PegHoleDistanceFromSideEdge
PegHoleSpacingExtended
SaddleHeightActionBass
SaddleHeightActionTreble
SaddleLength
SaddleRadius
SaddleThickness
SaddleZBassOffsetCompensation
SaddleZShiftOffset
SaddleZTrebleOffsetCompensation
SoundHoleDiameter
SoundHoleDistanceFromBodyTop
StringCount
TailBlockChamfer
TailBlockThickness
TailBlockWidth
TrussRodChannelDepth
TrussRodChannelLengthIntoBody
TrussRodChannelWidth
Step 3: Adjusting Parameters
After editing a parameter, you may see a progress bar at the bottom right and it may take from a few seconds up to a minute to update the design as the design history is somewhat heavy.
Adjust parameters to a reasonable amount as things can break if you stretch too far.
The full version includes the classical guitar headstock and bridge, cutaway, adjustable panel thickness, fret slots, full texture, tail and neck block, 7 pre configure designs and the export plug in function.
Step 4: Saving DXF Profiles
After you're done with your customization,
  1. ...open the python script that you can download with the full version, open it by pressing "Shift - S" to open the Scripts and Add-Ins window, and under Scripts, click the + button under My Scripts and locate the folder the script is in that you downloaded.
  2. To use the script just run it and a folder selection window will show up. Select the folder you want the exported DXF profiles to be in and click save. All DXF profiles will be saved. It includes both classical and standard headstock, both cutaway and non cutaway sides and top and back.
Step 5: Any Questions Are Welcome
To help further develop both this Instructables and the 3D project itself, please leave your feedback to help improve anything about the model and how to guide.
Thank You!
