Introduction: How to Disable 'Contactless Payment' on Your Debit Card
Call me old fashioned, but in my eyes having something in your back-burner that opens up new potential to being stolen from doesn't really fill me with confidence. This, twinned with recent media reports of duplicate (or more) payment processing for single purchases only adds to my initial pessimism of whether it's really worth the risk for saving what is essentially a few seconds at the check out.
So when my new debit card arrived I was frustrated to say the least when I noticed the Contactless Payment feature symbol -- something I was told I couldn't opt out of and get a card without.
In response, I decided to make an Instructable showing how I quickly and easily disabled the Contactless Payment feature in my debit card.
Please note that this is not reversible.
Step 1: Requirements
- Your Debit Card!
- Soldering iron (Yes, I know it's a sin to use it like this...)
- Exacto-knife or scalpel
- Pen (optional)
Step 2:
The Contactless Payment function of the card relies pivotally on its antennae. This is simply a repeated loop of insulated (usually via a thin layer of lacquer) copper wire. I won't go into the fundamentals of how this clever yet simply technology works as there are countless references to be found, but in short if you introduce a break in the circuit between the chip and the antennae in your card, the Contactless Payment feature will be disabled.
I was able to get a good idea of where the antennae for my card started/finished by taking a close look at the edges of the chip. On close inspection I could see brass coloured flanges on the left and right of the chip -- something that was absent from my last card which did not have the new feature. These flanges, or 'tabs', looked like a safe bet for where the antennae should extend from.
Step 3:
Once you have determined where the antennae is connected to your chip you can sever it. I decided to sever both sides to ensure that I 'got' everything, though in theory a single break in the antennae should suffice. To do this I simply used my soldering iron to create two sections either side of the chip.
While I did this I noticed that I was also melting my way through metal elements (the antennae) as well as plastic. This was reassuring as it confirmed I had found the right area(s).
You'll note from the picture that two brass tabs can be seen from which the antennae winding/loop was connected.
Step 4:
Left as it is the card will most likely get stuck in the ATM, so using your choice of sharp knife -- either an exacto-knife or scalpel for example, trim the scar plastic from around the melted areas. I know it may seem obvious but take care. I slipped twice but luckily just had two near misses.
Step 5: Finished!
And there you have it! A card that retains all but its Contactless Payment features.
3 People Made This Project!
- ehussam made it!
- kloopk made it!
- bobsmith652 made it!
35 Comments
8 years ago on Introduction
this works, but the best way is to microwave the card for 5 seconds (works for passports too)
Reply 1 year ago
wont that also disable the chip? If the chip is disabled the Bank may say WE disabled security.
Reply 1 year ago
yes it will but the bank couldn't prove it, I have had chips fail on several cards in the past from normal use.
6 years ago
Anyone who would like to follow this guideline should remember that this action may cause your card voided and confiscated by the merchant at instruction of card issuing bank because the card is tampered with.
Reply 1 year ago
Good reminder, around here no one looks at the card and since i use a pin it likely wouldnt be an issue but there is always the possibility. Thanks
2 years ago
This is the most insane thing I've ever seen...People from the United States (which has one of the highest CC fraud rates in the world) will literally hand someone their credit card at a restaurant for 20 minutes and not think twice... but won't trust advanced encryption built and trusted by most of the world outside of the US. Honestly, you do not need to mutilate your cards just because you don't understand the technology.
Also - won't this prevent you from using EMV terminals (the standard nearly EVERYWHERE outside of the US)?
Reply 1 year ago
He understands the tech well enough to disable it. I had to use this method because even though my card provider said they disabled it for me, it continued to work. The idea is to make the card harder to use if stolen. I have double verification on my card but the darn contactless bypasses it. soooo using this method is working for me.
1 year ago
Thanks a lot for this "instructable", NTT.
And thanks a lot for your addition, RyanA191!
I probably wouldn't have found out how to cut that new type of antenna on my own, and therefore I would most likely have had to revert to cash payment…
I used a very sharp pointed needle to interrupt the antenna. Works perfectly. It's almost invisible; and much easier to do than the previous cards requiring cuts all along the sides of the chip (but there's no need for a soldering iron, just cut alongside the chip).
[Here I'd have liked to add a photo, but that won't work. It was complicated enough to get this far, so I'll leave it at that. Sorry.]
Or, as Dougal32 says:
"The beauty of this method is that the card looks unmodified. Thanks so much Ryan and well done."
I second that!
Modern technology more easily usable again — great feeling.
As for m.kern's comment, saying:
"This is the most insane thing I've ever seen...
Also - won't this prevent you from using EMV terminals (the standard nearly EVERYWHERE outside of the US)?"
No, here in France this does not prevent me from using my Mastercard on EMV terminals, nor in cash distributing machines.
(The abbreviation EMV originally stood for Europay-Mastercard-Visa, later joined by JCB, American Express, China UnionPay, and Discover.)
For internet purchases my bank provides virtual card numbers, valid one time and for my specified maximum amount only.
The magnetic stripe I don't know: in over 25 years I never once used that feature.
Here a brief introduction to the technology involved.
The author, Renaud Lifchitz, is a security engineer working at BT (formerly British Telecom). Methinks he's someone who should "understand the technology" :
https://storage.googleapis.com/google-code-archive...
One particularly interesting point is the "advanced encryption built and trusted by most of the world outside of the US", as m.kern calls it:
There is NO encryption being used AT ALL !
(At least not here in Europe. Not back in 2012 when Renaud Lifchitz wrote his PDF, and not today in 2020.)
In addition to theft, there's another, largely underestimated aspect to such personal data freely available for the taking, and that's the possible usurpation of our identity. If criminals operate with false papers in our name, the resulting hassle will be far greater than trying to get a handful of stolen €uros back from our bank…
So just let me say:
Thanks again, guys, for this "most insane thing" !
2 years ago
If you are a Wells Fargo customer just call the number on the back of your card and request a non-NFC card.
6 years ago
If you don't want your card to be copied in the subway, but don't want to take any risk trying to disable it, an option is to wrap the card into aluminium foil. Just put the foil in both sides of the card (in fact covering one side is enoguh), and put it into your wallet. Make sure that the foil remains inside the wallet when you extract the card.
And additional benefit is that card won't interfere with your transport card any longer
Reply 2 years ago
i wonder if aluminum tape on the card would work...
2 years ago
i used this (or a similar technique) to disable my tap for a few years. a machine i used today detected that the tap was disabled :(
3 years ago
This is by far the best thing I have found online to date. A way to botch what I was told I have no choice but to accept. People are getting replacement cards forcing this agenda of tap and go and I do not care what anyone says it is just another way for would be hackers to steal money from my credit line. Not only that, someone could take my card while I am sleeping, and return it in the morning and the bank will be like, you still have to pay the bill. Not that this has happened to me before but there are people in this world that would steal the last dollar from their own mother. So hackers and would be thieves are potentially able to have their way here. Merchants never ask for credentials to verify who you are anymore. People can just "tap and RUN" so to speak. And I'm not having it. I told the bank I dont want it and they said I have no choice as they only give cards with this enabled. I see the bubbled area where the chip is and I searched online and ended up here. You better believe I will cut this chip out using whatever means necessary. I refuse to be force fed this agenda. There is more to it than convenience for us. It's about making it easier for us to spend more using credit and debit cards. Even if there is no interest, there are transaction fees at every instance of using a card. Banks have claimed that transaction fees can account for good bit of their gross profits and this just feeds that beast for tracking each and every bit of spending we make. It's a way to trace our moves and also track our flow of money being spent etc. So glad to know I can tell the credit card company I defaced their card because they refused to adhere to "MY" security protocols. I think we should also force them to sign disclosures and agreements when we agree to spend their money. They should have at least made it so people can enable and disable the function of tap and go. If they cant at least do that, you better believe they have a bigger agenda at work. Thanks for this DIY way to slam dunk in their faces
Tip 4 years ago
I used the method described above by RyanA191 and it works very well. After I cut the track I tried my card at two retailers who have machines that use the PayWave/Contactless feature and neither machine detected my credit card. The beauty of this method is that the card looks unmodified. Thanks so much Ryan and well done.
Tip 4 years ago
If your chip looks like this, then no amount of cutting the or drilling holes in the body of the card will disable the Pay Wave/Contactless feature, because the antenna coil does not run around the outside of the card, it is completely contained under this square. However, there is a solution. If you look at where the red arrow is pointing you will see a single "wire" running from the top right of the square back to the chip contacts. This wire connects the outside of the 11 windings of the antenna coil (buried under the chip) back to the chip contacts. Cutting through that "wire" anywhere along its length will disable the contactless feature but leave the chip and pin number functionality intact. Carefully use an Exacto knife (a.k.a Stanley knife, NT cutter, or Boxcutter) to cut the wire (the point where the red arrow indicates is easiest to get at. Use a fresh blade and be careful you don't slice yourself. You may need a magnifying glass and a strong light and some tape to hold the card down. If you can, its best to make two cuts very close together and remove piece between them (see the second photo). I have done this with three cards so far, and it has worked with all of them Good luck!
4 years ago on Step 4
basically I did what Loda 103 says and it works. just make a 1 cm cut in between signature stripe and magnetic stripe towards the chip.
4 years ago
hahaha well done, brute force! :P
4 years ago
Phrases including sledgehammer and nut come to mind :) shine your phone's led light thru the card to find the antenna then use a paper punch (used for paper filing) to make a neat hole in card. Job done.
6 years ago
I got a contactless card from Santander and I went to the branch and asked them to send me a non contactless card and it arrived in a couple of days.
7 years ago on Step 5
A small (1mm) hole drilled from the back in the right spot is all it takes - on my AE it was the bottom edge, though I found the top right corner of the card to be more reliable on other cards. Break one wire of the antenna and the induction cannot work. Tap and Go(ne).
