Introduction: How to Do a Magic Trick
In this magic trick you will learn how to turn any 4’s card into two 2’s you will need two decks of cards and from it you will need one 4’s card and two 2’s cards but they have to look the same. You need to hold them in order showing the four and nothing else, you need to have it in their eye line’s sight so they can’t see the other cards behind
Step 1:
Hold the 3 cards up 4 first and then the 2’s at the eye line’s sight so then they can’t seen it through different angles and make sure you and holding them all in one stack.
Step 2:
You need to practice a snap motion and move the four below and behind the two other cards. Once you are consistent and can do it very fast you will be able to work on the second step.
Step 3:
For the third and final step you will need to take the other 2’s card and do a swipe motion with your left hand to the left, and you will have to hold the 4 at the snapping motion and the two in the right hand. It’s a decently hard trick but with enough practice you can master it easily
