Introduction: How to Download and Install Faithful Texture Packs for Minecraft
Minecraft is an awesome sandbox game which allows you to do almost anything. Aside from that, it is also open-source. The developers of Minecraft have openly stated before that they are allowing texture pack creators and developers to create mods, and packs to make the game better. This helped birth Texture Packs.
Essentially Texture packs are visual enhancements and modifications for the game. They replace the original textures designed by Mojang with new ones, Each has their own different taste. There are medieval packs, cartoonish packs, high definition texture packs and even realistic texture packs. However, one type of texture pack has become the most popular - Faithful texture packs.
What is Faithful
Faithful texture packs are technically resource packs which modify the whole look of the game to look more crisp, smoother, and essentially better WITHOUT removing the original aspect and themes of the game. It remains “faithful” to the true essence and vibe of how Minecraft was originally designed to be. Hence, it has been called Faithful.
Millions of people are using Faithful daily, however there are still thousands of people who might not know how to download and install it. That is the reason why I have decided to write this article to help those in need on how to properly do it. Follow our steps and you’d be sure to play Minecraft with Faithful in an instant.
Step 1: Download Optifine
Downloading Optifine is a necessary first step which you will need to do once when installing any texture pack or resource pack. It allows you to run the game with the packs and provides new video and visual settings. These settings allow you to use higher resolution textures and shaders, and Faithful.
Here are the prior steps in installing Optifine:
1. Download Optifine
2. Unzip the file
3. Run the installer
4. Point to the proper directory
5. Click Install
Step 2: Download Faithful
There are several types of Faithful texture packs. You need to choose which one you would prefer, but the most famous ones are currently Faithful 32x and Faithful 64x. All you would need to do is click on the link provided above which redirects you to our Top Faithful texture packs list.
Afterwards, you need to pick which one you like, click on the download link, then start the download. You can save it anywhere you want, but putting it on the desktop would be best since we will move it anyways.
Step 3: Install Faithful to Minecraft
After you have downloaded the Faithful texture pack you desire successfully, please follow these steps.
1. Initiate the run command by holding windows button + R together at the same time
2. Type %appdata% and hit enter
3. Click on .minecraft folder
4. Click on resourcepacks folder
5. Copy the downloaded zip file and paste to the shaderpacks folder.
Step 4: Run Minecraft With Optifine Installed
In this step, all you will need to do is run the Minecraft version with Optifine Installed. Take note that you need to make sure that it is Minecraft with Optifine so that the shaders options would be available.
Step 5: Activate Faithful Texture Pack in the Game
After the previous step has been completed, Minecraft should have been installed if you have followed the steps properly. Now all you need to do is activate the texture Pack within the game.
After you have booted Minecraft with Optifine installed follow these steps
1. Click on Options
2. Click on Resource Packs
3. Click on Faithful to move it to the active resource packs list, make sure it is on top of the load order
4. Go back to the main menu and load any saved game.
5. Congratulations you have successfully installed Faithful
For anything Minecraft related, go to our website minecraft-resourcepacks.com.
