How to Draw Constructing: for Makers
Intro: How to Draw Constructing: for Makers
This instructable will cover the basics of manipulating shapes to construct complex figures, "building" your drawing, and seeing through form.
If you have not done so already I HIGHLY suggest looking through my earlier drawing Instructables before moving on.
The previous Instructables in this series covered the basics of selecting drawing tools, drawing posture, making a straight line, drawing in 2-point perspective, adding shadows and dimension to drawings and simple rendering techniques.
Here are my other drawing Instructables:
https://www.instructables.com/id/How-to-Draw-For-Makers/
https://www.instructables.com/id/How-to-Draw-Perspective-For-Makers/
https://www.instructables.com/id/How-to-Draw-Perspective-II-For-Makers/
https://www.instructables.com/id/How-to-Draw-Rendering-For-Makers/
STEP 1: Exploring Surfaces
Start by exploring the surfaces of a simple form by drawing contour lines.
Contour lines are lines that lie on the surface of an object and follow it's perspective.
This will help familiarize you with edge transitions and seeing through a form.
Keep your drawing large (greater than 3 inches) and make sure the initial shape is accurate.
Then draw a continuous line across the surface that explores all sides of the figure. Keep the line in perspective with the sides and only turn at 90 degree angles.
Practice this alot and try out cylinders too!
STEP 2: Cutting Shapes
One method for manipulating simple shapes to create more complex figures is my cutting away or subtracting material.
I like to think of constructing a drawing the same way as sculpting clay. You start with a basic "block" of material and then "find" your final shape inside by cutting away and adding material as needed.
Building complex shapes out of simpler shapes will help keep your perspective accurate and break down the drawing into easy to manage figures.
I don't draw a car by starting directly with a "car" shape. I draw a car by starting with a car sized rectangle and go from there.
Let's start by cutting one of the edges off of a cube.
Keep practicing different cuts from different angles. You might even want to experiment with adding tone or casting a shadow.
STEP 3: Intersecting Shapes
Another way to manipulate shapes is by adding material or intersecting two shapes.
Let's put two cubes together.
Remember to always draw through your shapes so you can see the interior lines.
Now try it out with other shapes. What can you build?
STEP 4: Constructing Complex Geometries
Look at the objects around you and think about how you can pull them apart visually into simpler shapes.
What shapes are the computer you're reading this on made of?
If it's a laptop it's probably two rectangles. Maybe there's a cylindrical hinge and lots of tiny rectangular buttons.
Developing the ability to visually break apart complex shapes is essential to advanced drawing.
You can practice this skill even when you don't have access to a piece of paper just by analyzing forms and thinking about how they're constructed. Pretty soon you might find yourself thinking about it without realizing it!
What shapes are hands made of? Can you see how I structured them and built the fingers out of tapered cylinders?
These chairs might seem complex, but they're just a bunch of curved rectangles!
Keep a sketchbook and keep practicing! Try to draw at least one page a day.
Find a sketching buddy. This will not only help motivate you to keep drawing, it'll also give you a source of external input.
It's important to have others look at your work. Just like you might have someone proof read your essay for grammatical errors you should have someone "proof read" your drawings for perspective errors.
I certainly wouldn't be where I am without input from my teachers and peers.
Drawing is an excellent way to communicate your ideas to others, your drawing buddy can ensure that your drawings are clear and coherent. Try to keep the audience in mind when drawing and create a narrative that the viewer can understand without explanation. Ask yourself, can your drawings stand alone without you there to answer questions?
13 Comments
JON-A-TRON 9 years ago
Suddenly, those gorgeous industrial design drawings I envy don't seem so unattainable. I'll get back to you in a few weeks...
rlciavar 9 years ago
Yay! post your progress! Your CAD furniture designs would look awesome as marker renderings
AH Electronics 9 years ago
I thought drawing is the hardest thing to explain, but you did it in class!! Excellent job! Really appreciate all the effort you put in to make this tutorials easy and understandable!
AJMansfield 9 years ago
The "adding tone or casting a shadow" part is actually my favorite part. For even more fun, try refracting the hidden lines and perhaps adding a simple checkered surface under it once you get here. Its not really that hard once you get the hang of it - you just have to visualize a few raytraces to figure out where everything goes and how any curved surfaces will distort things. (Or, for something still harder, make it reflective!)
Gabo19 9 years ago
mur7 9 years ago
very good clear idea thanks
GP Spampinato 9 years ago
Great series! I think I might take up doodling in my free time!
gtkindust 9 years ago
Downloaded pdf file does not contain the images shown here. The pdf is only four pages.
Maybe try taking screen caps of the pages
andrea biffi 9 years ago
very nice tecnique and drawings, thanks for posting
sandrone75 9 years ago
Danger is my middle name 9 years ago
Very nice explanations and examples! Good job!
watchmeflyy 9 years ago
Everything is very well explained, and you make drawing seem so easy! Great encouragements too. ^^
