Introduction: ❤ How to Draw a Heart in Photoshop
Learn how to draw a heart ❤ quick and easy. For this tutorial I will use Photoshop and a grid pattern to draw a heart. But, you can use a similar technique to draw a heart on paper.
Step 1: Add the Grid Texture in Photoshop
First, open a new Photoshop file. Set the width and height the same size to make a square canvas. I will use an 800x800px canvas.
Set the background color white. Then, add this grid png image in a new layer. Set the opacity to around 30%.
You can also use these grid Photoshop brushes or you can press Control+' to add the Photoshop default grid system.
Step 2: Add a Square Shape
Use the Rectangle Tool to add a square shape. Keep the Shift key pressed to make a square not a rectangle. Set the blend mode to Multiply so that you can see the grid below.
Step 3: Add Dots on the Drawing Grid
Create a new layer and use the Brush Tool to add some dots that will help you with the heart drawing.
Step 4: Use the Pen Tool to Draw the Heart Shape
Pick the Pen Tool and make sure that the Pick Tool Mode is set to Shape not Path.
Click on the dot marked with "1".
Step 5: Add Anchor Point in Photoshop
Click on the dot marked with "2". Keep the Shift key pressed and drag to create a rounded edge.
Step 6: Draw the Heart Shape
Continue to add anchor points. When you need round edges, keep the Shift key and drag. When you need a sharp point, simply click.
Step 7: Heart Custom Shape in Photoshop
This is how you can create an easy heart vector shape using Photoshop. To draw a heart on paper is just as easy if you follow these instructions.
If you want to use the Photoshop heart shape in other projects, make a custom shape. Right click on the heart and choose Define Custom Shape.
Step 8: Download the Heart PNG
Hide all the other layers (background, grid, square) and download the heart PNG image.
Step 9: ❤ How to Draw a Heart in Inkscape
Inkscape is a professional open-source vector graphics editor used to create vector images and it is considered the free version of Adobe Illustrator.
Drawing a heart in Inkscape is similar to drawing a heart in Photoshop. First, copy paste the grid png. Then, use the Bezier Tool to draw a heart shape.
There is also another method that you can use. It is probably the easiest method to create a heart shape.
Use the mouse to select a heart symbol or a heart emoji from this list. Press Control-C to copy the text symbol.
Step 10: Insert Heart Symbol in Inkscape
Add a Text in Inkscape and press Control-V to paste the heart symbol.
Step 11: Inkscape Convert Text to Path
To convert a text line into object, go to Path > Object to Path (Shift+Ctrl+C).
Step 12: Download the Heart SVG
This is a simple method to draw a perfect heart. You can now download the heart SVG image.
Step 13: ❤ How to Draw a Heart on Paper
To draw a heart on paper, you need a ruler to draw the grid. Add some grid points to guide you. Then, draw the heart shape using a pencil. Use a marker to trace the heart shape. Finally, erase the grid lines.
