Introduction: How to Draw a Snowflake
Snowflake is a tangible symbol of winter, always pleasing you with winter mood. Who does not like to make snowflakes? After all, it is an absolute miracle to draw and cut out snowflakes with your child. Today I will teach you how to draw a snowflake - arm yourself with a pencil and a ruler!
Step 1: Step 1. Draw the Outline of the Shape
The first step to drawing a snowflake is to draw the outline of the shape. Using your pencil, sketch a skeleton figure of the shape. The outline should look like a snowflake. You can add or delete lines to reveal the shape. You can also color the outline to make it more attractive. Now you're ready to start drawing! Here's how to draw a snowflake.
Step 2: Step 2. Draw a Vertical Line
The next step is to draw a vertical line. It doesn't have to be perfectly straight. Use a ruler to ensure that the line is straight. Next, draw a diagonal line that goes around the middle mark. The diagonal line should curve the other way. The lines should all be the same length and space between them should be equal. If you want to make a perfect snowflake, repeat these steps. You can also use a pencil to draw the outline.
Step 3: Step 3.
The next step is to add a thick blue line at the bottom of the big branch. Follow the angled line until it meets the circle. You can erase the pencil lines when they are dry. Then, color the rest of the snowflake with a light blue marker. Once you've finished coloring your snowflake, you can start drawing the outline of your snowflake. Remember that it's important that the design you create looks symmetrical from all sides.
Step 4: Step 4.
After you've drawn the outline, draw the snowflake. Most snowflakes are white, since it reflects light better than any other color. But you can try different colors to make your snowflake unique. The first step is to sketch the outlines of the snowflake in a simple, yet creative way. One way to make a unique snowflake is by making a letter X figure and adding a letter V shape on each line. Then, you can highlight the outlines of the X with a different color. Continue this step until you've drawn the entire image.
Step 5: Step 5.
The next step is to draw the outlines of the snowflake in detail. After you've outlined the outline, you need to create the actual snowflake. Then, make a star section of the snowflake out of the star. After that, you can now make the inner lines more complex by adding different shapes. Once you've completed the inside of the snowflake, use a pencil or a pen to erase the extra lines.
Step 6: Step 6.
Once you've sketched the outline of the snowflake, you can add the snowflake's arms. The 'V' shapes should be the same color as the letters 'V'. After that, you need to draw the 'V' further up, and add small arms. Then, draw the 'V' shapes further apart and make them look like a single unit. This is only one example of drawinf a snowflake. Search for different snowflake vector illustrations on the web and create incredible winter artwork.
