Introduction: How to Emboss Metal for Beginners
Metal embossing has always fascinated me so when I came across a metal embossing kit on clearance, I couldn't resist.
If you're into adult colouring books, or paint by numbers, this could be something fun and different to explore!
- Metal embossing tools. The kit I have is no longer available, and I couldn’t find a similar quality set on Amazon. So search your local market for ball, teflon tools and embossing wheels if you want to expand from a beginner project like this. In the interim, an empty ball point pen will trace just fine. Clay sculpting tools will work if you have them. I also noticed some interesting engraving heads on my soldering iron set that would also work (no need to plug it in)! Try whatever you have on hand and just have fun with it.
- Paper stumps
- Embossing Foil
- Foam sheet. A small piece is great for a beginner project like this, but you may want a larger sheet for bigger projects (like the one linked). Alternatively, a stack of paper can work too.
Step 1: Amara Nominated Blog!
Before we get into the Instructable, we're excited to share that Birdz of a Feather has been nominated for an Amara blog award! Please take a moment to support our nomination and vote for us here :). Voting closes September 9th, 2021
Step 2: Gather Supplies
After watching a few videos to understand the principles of embossing I decided to do my own thing, as I always do :). So out comes a stencil to play with!
Using a ruler to provide a straight edge, I first create an outline around the piece of metal with the embossing wheel you see above.
Position the stencil where you want it, then tape it down to the metal so it can’t shift. This will end up being the ‘right’ side.
This step happens on a hard, smooth surface. Trace the outline of the stencil onto the metal.
Flip the whole thing over. Now you can easily see the shape of the hearts. Use a paper stump to rub along the entire inside of the pattern.
Step 3: Create Depth
Look at the difference in definition; the upper right heart now has more depth.
Here’s all four hearts after using the paper stump.
After flipping it over to the right side, you can see that the depth of the hearts can’t go any deeper than the thickness of the stencil. But we can change that in the next step.
Step 4: Remove Stencil
Once I remove the stencil, I further define the hearts by retracing around the edges with a ball tool.
But now we’re going to introduce a piece of foam to add depth. Placing the foam sheet under the work and rubbing again with the paper stump will really emphasize the embossing!
The addition of the foam allows the hearts to sink deeper. The more you rub into the foam, the more the metal will stretch to emphasize the relief.
Again, flipping to the right side the hearts really puff out. Isn’t the 3-D effect amazing?
Step 5: Create Dots
Still use the foam. This time I’m adding dots using a larger ball tool to mark a divot in the metal.
With the smaller ball tool, spin it around the edges and work into the middle. That makes quick work of puffing out the dots!
Step 6: Importance of Taping Stencil
To demonstrate how important it is to tape the stencil to the metal, I’m going to ‘wing it’, by not taping the stencil down.
The top diamond shape turns out pretty good, but the one my finger is pointing to on the bottom is much less defined. It’s REALLY difficult to get detail on a stencil when it’s not secured well to the metal.
Here’s my beginner sampler using a stencil to emboss.
Step 7: Embellish a Box
So, what can you do with your first practice piece? I’m upcycling a thrifted photo box.
Apply the metal embossing to the recess of the photo box! Since all my printed pictures are 4″x 6″, and I don’t want to chop one up to fill the windows on the end, applying a decorative panel like this embossing is ideal!
Imagine doing this on a larger scale to fill in the panel on a cupboard door! Wouldn’t that be cool? One last tip. For this little project I didn’t bother because it's inset into a panel. But for metal as deeply embossed as this, it’s suggested that the back is filled with beeswax so the embossed parts can’t accidentally be dented.
Get Your Craft Mojo On
If you enjoyed embossing on metal, subscribe to Birdz of a Feather. You can also follow us on Pinterest, Facebook, YouTube and Instagram.
Step 8:
Fall Into Fabulous
One of the things I love most about blogging is connecting with other makers, and this Fall we’ve created something truly inspiring together.
Grab 16 digital goodies from top creators — planners, recipes, colouring books & more — including our Beginner Crochet e-Book!
Every dollar of our commission goes straight to Alzheimer’s research — a cause close to our hearts. Your purchase through this link means you’re not just treating yourself; you’re making a real difference.
Grab it now — the bundle is only available for a limited time! Let’s make this Fall fabulous and full of hope. 💜
