Introduction: How to Enable USB Debugging on Android Phone?
About: My name is Jocelyn, I've been writing about mobile & photo editing for more than 2 years. Follow me to learn anything related to technology & photo editing.
As an Android user, you must have to know what is USB Debugging and Developer Options. The main function of enabling USB debugging is to give you access to the data inside your Android phone and tablet. If you want to have much more freedom of control over your phone, such as having your phone connected to computer, you should read this article detailedly introducing How to enable USB debugging on Android.
Step 1: Enable USB Debugging on Android 7.0 and Android 8.0
To enable USB Debugging on Android Nougat and Oreo are just the same as what you do on other version of Android, from Android 4.2 to Android 6.0. Here are the detailed steps for you to follow.
First, enable Developer Options: Go to Settings > About Phone > scroll down to the bottom > tap the Build number seven times.
Then, enable USB debugging: Go back to Settings again > enter Developer Options menu > switch on the toggle button of USB Debugging > click OK to allow USB Debugging when a pop-up appears.
Disable USB Debugging: Settings > Developer Options > debugging > USB Debugging.
Step 2: Enable USB Debugging on Android 4.0 and 4.1
These steps are just like steps above.
Go to Settings > enable Developer Options > scroll down to USB Debugging option > tick it.
Step 3: Enable USB Debugging on Android 2.3 Gingerbread and Earlier
To enable USB Debugging on Android 2.3 and earlier is a bit different from the steps above but it is also simple enough.
Go to Settings > Applications > Development > USB Debugging > Enable it
Step 4: How to Identify Which Android Version Is Your Android Phone?
If you want to know the right way to enable USB Debugging on your Android phone and tablet, you should first know the Android version of your device. To know that, you can go to Settings and scroll down to the bottom, and find the "About Device" option. Enter to this menu and you can see many details of your device. Look at the "Software info" or "Android version", and you will know which Android version is your Android device.
