Introduction: How to Enable Wi-Fi for Your IoT Gateway
Wi-Fi is a natural choice for connecting Internet of Things (IoT) devices in both residential and commercial settings due to its widespread use and popularity in delivering the internet globally. With its extensive capabilities and widespread adoption as a worldwide standard, Wi-Fi is ideally suited to enable IoT goods and applications. In practically every IoT scenario, Wi-Fi will be used, either by itself or in conjunction with more specific protocols or technologies.
Wi-Fi Competencies for IoT Projects
Standards-based and interoperable technology
Pervasive global connectivity
Proven WPA3™ security
Cost-effective and easy deployment
Strong Compatibility with Legacy Devices
Location-aware IoT Services
Heavy Data Throughput and Low Latencies for Video Streaming
Flexible Network Topology
A router or a computer that can login to enter IoT gateway's IP address
Step 1:
Steps to Setup Wi-Fi for IoT Gateway
STEP 1: Open A Web Browser on a Computer or a Router
Launch a web browser from a device, The device can be a computer that is directly connected to the gateway or a client from a router that is connected to the IoT gateway.
STEP 2: Log in to the IoT Gateway
1) In the address field of your web browser:
Enter http://192.168.66.1 for a computer web browser; or log in to the router, and find the gateway’s IP address (IP_addr), then Enter IP_addr.
2) In the Login field, enter the gateway password and click the Login button. The default password may be: root (case-sensitive).
STEP 3: Configure the IoT Gateway
1) Select Wi-Fi Manage, and enable Device Radio0 and configure Wi-Fi Interface WLAN0(Wi-Fi Mode: AP, Wi-Fi SSID: Input your own; Wi-Fi Encryption: PSK2 or others; Wi-Fi key: your password);
2) Click the Save & Apply button, and wait for the above-mentioned changes to be applied;
3) Connect the IoT gateway through Wi-Fi.
The Wi-Fi configuration for Your IoT gateway is done! Then you can use Wi-Fi to implement your IoT projects.
