How to Etch a PCB
174,870
90
17
Introduction: How to Etch a PCB
All materials used in this instructable came from the PCB Fab-In-A-Box Starter Kit which can be purchase here. You will also need to purchase some PCB Etching Solution.
Step 1: Design
First you need to design the board using a service like Eagle, Fritzing or you can even just use Adobe Illustrator if you know exactly what you want. And remember to flip the design once you have it complete before you print it out.
Step 2: Print Out the Design Onto the Shiny Side of the Transfer Paper
Step 3: Sand the Copper Plate So There Is a Rough Surface for the Design to Stick to When Transfered
Starting from this point on you should use surgical gloves to handle the copper plate and etching solution, this helps avoid getting oils on the copper and chemicals on your hands. When sanding do an extra good job on the edges.
Step 4: Wash the Copper With Some Water and Rubbing Alcohol and Let It Dry
Step 5: Cut Out the Designs and Place Them Face Down on the Copper
Try and have some margins around the design this also helps the ink stick to the plate.
Step 6: Run the Copper Plate With the Design Face Down Through a Laminator 5-7 Times Until the Plate Is Hot
You can also use a iron instead of a laminator if you dont have one.
Step 7: After Running the Plate Through a Laminator or Iron Place the Plate Into a Cold Bath and Agitate Until the Paper Floats Off
Step 8: Place the PCB Into the Etching Solution and Agitate for 25-30 Minutes or Until All the Copper Has Dissolved Around the Design
If you would prefer not to agitate by hand here is another instructable I created on how to make a agitator using an old CD-ROM drive.
Step 9: Once All the Copper Is Gone Rinse It in the Water Bath, Let It Dry and Use Rubbing Alcohol to Whip Off the Ink Transfered Onto the PCB
Step 10: And Now You Have a Etched PCB Board But You Still Need to Drill the Holes
The best way to drill the holes out of a PCB board is to use a dremel, a 1/32 inch drill bit and it would be best to use a dremel press but if you cant do that you can clamp down the dremel and bring the board to the dremel by hand to drill the holes. Good luck and have fun!
DISPOSAL NOTE:
Also since the etching solution eats copper and is some what toxic you really should dispose of it with other hazardous materials and definitely DO NOT POUR IT DOWN THE DRAIN it will eat up your copper pipes!
UP! Contest
UP! Contest
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    • Big and Small Contest
    17 Comments
    MattW107
    MattW107
    6 years ago
    Uhhh is it just me or are there broken traces there?
    liamguyorourke1984
    liamguyorourke1984
    Reply 1 year ago
    regardless of whether they are traces or not they were meant to transfer as solid lines... and they didn't. DIY PCB photo etching doesn't cost much and so long as it's done right can produce very nice results.... plus it's actually cheap to do.
    Here: this guy has put together a pretty cool tutorial if anyone's interested: -
    https://www.youtube.com/watch?v=tWnfnt2rNO0
    lukemeish
    lukemeish
    Reply 6 years ago
    There is, not just the border, but right above it as well.
    lotus49
    lotus49
    Reply 6 years ago
    It is just you.
    That's the outline of the board not a trace.
    ocurran24
    ocurran24
    Question 5 years ago on Step 1
    Once the design is completed, why do you have to flip it before printed?
    SachinP75
    SachinP75
    Answer 3 years ago
    Exact design is the way you see and you need to flip it while pasting the paper in copper board and end up etching the mirror image. If you already flip the design, flip of the flip will be exact design. Hope you got it.
    AamirA24
    AamirA24
    Question 4 years ago on Step 2
    What kind of paper should be used??
    WaleedYounas
    WaleedYounas
    Answer 3 years ago
    photo paper
    GillynS
    GillynS
    What kind of Paper was used here? thanks
    WaleedYounas
    WaleedYounas
    Answer 3 years ago
    photo paper or glossy paper
    Andre82693
    Andre82693
    5 years ago
    Hi and thanks for your help I have a problem with finding the right paper for this project . Do you have a brand or model number of paper you have used that works well. I am using the Iron on method with MG Chemicals Ferric Chloride etch
    shahbaz11
    shahbaz11
    Reply 4 years ago
    photo paper or butter paper is best
    Dinoman217
    Dinoman217
    6 years ago
    just a question; When you say "agitate" do you mean scrubbing the PCB by hand?
    nodoubtman
    nodoubtman
    9 years ago on Introduction
    After the iron,under the copper it's all black, is it possible that my
    iron is too hot, the iron settings is before steam. What do you suggest?
    thank you!|
    MikB
    MikB
    10 years ago on Introduction
    OK, I took my PCB down the local office supplies place, and they ran my PCB through the laminator 5 times, now it's covered in a massive layer of plastic, help!, how do I clean it off :)
    What, no plastic pouch, you say? Oh ...
    dannewoo
    dannewoo
    Ah yeah so I didnt find it necessary to use the plastic. But you can just sand it off and start again so the PCB is not wasted.
