How to Field Strip a Jennings J-22 .22lr Pistol
101,252
17
6
Introduction: How to Field Strip a Jennings J-22 .22lr Pistol
The Jennings J-22 .22lr pistol is very simple to field strip. This gun is definitely not top of the line but it was my first so i have gotten attached. It has preformed well but is somewhat picky with ammo CCI Minimag is best. This instructable will show you how to field strip the J-22 for cleaning and inspection.
Step 1: SAFETY FIRST Make Sure the Gun Is Not Loaded.
You start by finding a location free of disturbances such as running children, flying animals or other things that may take your attention away from the task at hand. If not it could actually kill you so.... BE CAREFUL. Once you have chosen a safe location make sure the gun is not loaded if it is unload it. If the gun is not loaded check to be sure the gun is not loaded.This is done by removing the magazine and pulling back the slide to visually inspect the chamber to ensure no rounds are present ok one more time the gun should have no bullets. got it? good.
Step 2: Taking Down the Slide
Taking down the slide is easy once you get the hang of it. First you will need to move the slide back 1/4 in. Now take the magazine and use the front lip to press in the take down pin. With the slide back and the pin depressed the rear of the slide should lift off of the frame. BE CAREFUL when letting go of the take down pin, it is spring loaded and if you're not careful it can fly across the room and land behind a shelf or some other place that you have to go search for it . Finally the slide can be pull forward off of the frame.
Step 3: Removing the Firing Pin
Simply pull the Take-down pin and spring out of the rear of the slide, sometimes the pin will come to if not just tilt back the slide and it will fall out. Be sure to put the firing back in the right way, proper way is shown in picture below. That about does it other than the fire control group behind the grip plates but i don't go digging in to the guts unless there is a reason but if i do I'll update this i'ble. Re assembly is in reverse order same steps apply only backwards. Thanks for reading and be safe.
6 Comments
Question 8 months ago on Introduction
do you have a parts list for the J-22 hand gun ? I've seem to have lost the retaining piece for the firing pin.
Tip 2 years ago
Pistol must be dry fired before disassembly
6 years ago
The J-22 was the first pistol I shot. Ammo picky, constant slide bites, soft frame and slide but... every time I shoot it, I'm hit with pleasant nalstalgia.
Reply 2 years ago
Try Remington Thunderbolt
4 years ago
My experience with ammo the Remington Thunderbolt works flawlessly up to 50 rounds, then the J-22 says Clean Me
Reply 2 years ago
Same here Thunderbolt works the best in all mine.
JA-22 and two J-22's
