Introduction: How to Fix a Weed Eater - Carburetor Cleaning
We have all had a time where are weed eater just wouldn't start. So we dump it in the car to go to the small engine repair shop so we can spend money, a lot of money. Little did we know that fixing this pesky, no good weed eater was extremely simple and required no tools.
Note: This will work on blowers, edger, trimmers, hedge trimmers, any 2-stroke engines
Step 1: Tools
Alright, this list is very hard to remember. You might want to press that share button and email this list to yourself.
Ready??
Tool Required:
-Flathead Screwdriver
Let me repeat it to pound it into your brain,
That's really the only tool you will need! Everyone has a screwdriver, and if you don't, then well... umm... you get the point.
Step 2: Special Repair Knowledge
This repair requires knowledge, just like any repair. Unlike most small engine repairs, this one requires a special knowledge. Ready to see if you got what it take? Let me have a questionnaire. If you answer yes to any of these questions, you qualify to be smart enough to do this repair.
Questionnaire:
1. Do you have a pulse?
2. Do you have opposable thumbs?
3. Do you have a degree in advance small engine repair?
Ok, so the last one wasn't necessary, but I ran out of qualifying questions.
Step 3: Get to the Carburetor
To get to the bolt that hold on the carburetor:
1. Remove air filter cover
2. Remove air filter
Consult to the video if you do not understand (it is on the last step)
Step 4: Open the Carburetor
There will be two screws that hold the primer bubble in place.
Unscrew those and it will split the carb in half
Again, consult to the video
Step 5: Unclog the Filter
This is the most important step because this is the only reason why we opened the carburetor.
Of course you can skip this step, but then you just wasted ten minutes and you will need to stop by the repair shop.
Step 6: Put the Carburetor Back Together
All you have to do with this step is repeat the previous steps backwards. Does that make sense??? If it doesn't you might as well pack up the pieces in a box and take it to a small engine repair shop to give them a $100 dollar bill.... Or you could just watch the video on the next step.
Step 7: Finished
Now that your weed eater is put together, it should fire up.
This will work if you can start your weed eater, but it will shut off. Most likely it will not fix a weed eater that doesn't start up at all. If that is your case try this and replacing the spark plug.
The Video!!!!!
All the previous steps are shown in this video
Please take the time to like, comment, and subscribe to this video. If you have any questions about small engine repair, please leave a comment here or in the video and I will answer to the best of my ability.
If you are on a mobile device, go to the direct link:
https://www.youtube.com/watch?v=gNzAfe28CyM
