Introduction: How to Fix a Zipper Pull
It can be frustrating when a zipper pull snaps and comes apart leaving you with nothing to hold onto to open your zipper. With FixIts and a paperclip you can create a new pull in under 5 minutes.
Ways to boil water :
- Kettle
- On a hob in a pan
- Heat cup of water in Microwave (without the FixIts stick)
Vessel (avoid plastic as FixIts can stick to it)
- Glass cup or
- Ceramic cup
Tools
- Hairdryer
Paper clips
Step 1: Attach a Paperclip Through the Zip Loop
Thread you paperclip through the zipper as shown
Step 2: Soften the FixIt Stick
Heat your FixIts stick up and pinch off what you need
Step 3: Mould FixIts Around the Paperclip
Mould your molten FixIts around the paperclip and give it a smooth finish.
Step 4: ProTip to Reheat Fixits
If you make a bit of a mess of it the first time around, you can always reheat your FixIts to make it soft again, at which point you can reshape it and give it a nicer finish.
Step 5: Zip Up!
Test your repaired zip out.
