Introduction: How to Fix Loose Tiles
steps
1- prepare the surface
2- prepare the mix
3- poor the mix and fill the gape
4- finish and clean
Step 1: Collect Your Tools
white cement
some nails
steel brush
epoxy resin for concrete (optional )
Step 2: Prepare the Surface
remove any dirt
remove old joint with nails
remove any sand ,old cement under the joint by using the steel brush
it should look like clean and deep
Step 3: Make the Mix
mix the white cement
with water and epoxy solution
1 liter of water + 250 mll of epoxy
Step 4: Poor the Mix
Step 5: Clean and Put Some Weight
clean the excess white cement and put some
weights on the tale
