Introduction: How to Fix the ABS/Traction Control Light on a 04 Impala
This Instructable will show you how to cheaply and easily fix the ABS/TRACTION CONTROL light that comes on your car. Don't let the mechanics take your money! this is EASY and only take a few mins to fix.
Step 1: Things You Will Need
Once again, as with all of my Instructables I give this warning.
WARNING! I AM NOT A MECHANIC! I WILL NOT BE HELD RESPONSIBLE FOR ANY DAMAGES THAT YOU DO TO YOURSELF AND YOUR CAR IF YOU CHOOSE TO FOLLOW THIS!
Here is a small list of things that you will need in order to fix this problem.
Di-Electric Grease (I did not have this so I used White Lithium grease, better than nothing)
socket wrench
Metric socket set
Soldering Gun (optional)
Solder (optional)
Heat shrink tubing (optional)
Wire brush
Lighter(optional)
socket wrench
Metric socket set
Solder (optional)
Wire brush
Lighter(optional)
Step 2:
when you go to start your car sometimes or all of the time does the ABS/Traction Control light stay on even if you push the traction control button? If you have a scanner it will tell you it is a part of a malfunctioning ABS system or bad ground somewhere.....Mechanics will tell you that it is the most expensive part of that system that needs to be replaced, Your ABS, hub, speed, sensor, pump module..ect, ect.
The scanner is right, it is a bad ground connection but all of these things do not have individual sensors to tell you if it is the ground on that particular part that is bad/needs maintenance.
I had this same problem and was horrified to find out what this can cause your car to do if not fixed. Some of the things your car will do at any time while you are driving it without your doing are: Depress (or better know as STEP ON) the brakes, shut the entire car off, cause the pressure of the brakes to intensify/lessen while you are stepping on them (lets say you gently tap on the brakes, they will act as if you slammed on the brake pedal of vice/versa)
Step 3: The Fix
First locate your ABS pump module (INSPECT IT, if it looks like it is leaking or you see leaking you should replace this part), it is on the Driver side of the car, go to the unit and trace the black wire coming out of the module and follow it to the driver side fender, it is bolted to here (see the pics). this is either a Metric 10 or 13 bolt, unbolt the lug, put the bolt and the lug somewhere on your car were you can clean it off (you only have a few spots, the wire is not that long.) I used the cars ECU/computer, it was exposed from removing my Air filter and it was flat.
Put something to cover the ECU so that it does not get scratched/damaged by this.
Use the wire brush and clean the lug, and bolt, and even the bolt hole. get all of the grime off of these, all parts should look nice and shinny when you are done.
Apply Di-Electric Grease to both sides of the LUG, on the bolt, and in the bolt hole.
Apply some Di-Electric grease on top of the bolt and the remaining visible surface of the Lug all the way to the wire housing, (don't leave any metal surface uncovered)
YOU ARE DONE! pat yourself on the back, you just save several hundred dollars by doing this yourself.
Step 4: Optional
If you have the optional materials then you will definitely save yourself the headaches from doing this all over again.
While the lug is unbolted heat up your soldering iron and apply some solder where with lug was crimped onto the wire were the wire is exposed on both sides of the crimp.
Put heat shrink tube over this all the way to the end of the crimp where the now soldered wire is showing.
Grease up everything and tighten the bolt back down.
This FIXED my problems. NO MORE ABS/Traction control lights! If this does not work for you try this on top of this fix
You will need some more tools for this, a Jack, and a tire Iron to remove the lug nuts of your tire. Plus wire cutters/strippers and a torque wrench and metric socket set
There has been several articles that Gm released on this harness not being assembled good and the connections that the wires are crimped to that goes into the harness have failed. A simple fix to this is to first use a scanner to find out what wheel the error code is coming form(you can just take it to a mechanic they will do this for you , it might cost or not depending on how shady they are) turning your cars wheels to the opposite side that the code is showing (if driver, turn wheel toward passenger), Turn off your car, jack effected side up, remove the tire with tire iron, disconnect the harness that goes to the ABS wheel hub, cut (MAKE SURE THAT THE HARNESS CONNECTOR THAT YOU ARE ABOUT TO CUT MATCHES THE ONE YOU ARE GOING TO SOLDER ON)and solder on the new harness connection. It is around $45 or so at Autozone, you can also check Amazon, or Rockauto for this part (you want the ABS Wheel HUB connector). put your tire back on, lower your car, torque down the Lug nuts and start your car.
This SHOULD FIX THIS PROBLEM. But if you are like me and do not fix anything until it needs to be fixed then THESE PARTS ARE 10 YEARS OLD, and might need replacing if you have not done so at all.
You can check Youtube to find a how to video on to replace the ABS hub on either side of your car if you still have this problem... I will post an Instructable on how to do this when I do so for my car.
