Introduction: How to Create a Beacon in Minecraft
This is a Minecraft step-by-step tutorial on How To Create A Beacon.
There will be 2 sizes.
Step 1: Materials
The Materials you will need are:
-Emerald block, diamond block, gold block, or iron block
-Beacon
-Iron Ingot, or a Netherite Ingot or Gold Ingot or a Diamond or Emerald (NOT the block)
Step 2: Begin the Frame
-Size Small:
Begin the frame by adding 3 of the listed blocks in a straight line across. Refer to the picture.
-Size Large
Begin the frame by adding 9 of the listed blocks in a straight line across. Refer to the picture.
Step 3: Finish the Frame
-Size Small
Finish the frame by adding 3 blocks to all 3 remaining sides. Refer to the picture.
-Size Large
Finish the frame by adding 9 blocks to all 3 remaining sides. Refer to the picture.
Step 4: Finish the Size Small Beacon, Continue the Size Large Frame
-Size Small
Fill in the last block and add the beacon on top. Refer to the picture.
-Size Large
Put a 7x7 new frame one block over but inside the 9x9 old frame. Refer to the picture.
Step 5: Continue the Frame for Size Large
-Size Large
Add a 5x5 one block over but inside the 7x7 frame. Refer to the picture.
Step 6: Finish the Frame for Size Large
-Size Large
Add a 3x3 frame one block over but inside the 5x5 frame. Then fill inside the one block hole, and then add the Beacon. Refer to the picture.
Step 7: How to Draw Power Out of the Beacon
Take your Netherite Ingot or your Gold or Iron Ingot or your diamond or emerald, and place it into the empty spot on the left. Then press the power you choose, and press the checkmark and then you will notice a power on the top of your left screen. Refer to the pictures.
Thank You For Reading!!
If you wanna see more Minecraft tutorials, check out WolfxZ39!
