Introduction: How to Get Those Stuck Grips Off Bike's Handlebars
Sometimes people need to take their grips off a bike's handlebars, but often the only way to do so appears only to cut them. This instructable tells you how to do this in another way. You will need:
- a pair of grips to take off,
- water, and
- a flathead screwdriver.
Step 1:
First start off by taking a flathead screwdriver and slightly pushing it in between the handlebars and the grip.
Step 2:
After doing that, gently push the screwdriver sideways, leaving a small gap between the handlebars and the grip. After that, pour some water into the gap and remove the screwdriver. Originally I used wd40 (a penetrating oil) but later found out that simple water works just as fine and you don't need to clean anything up after it.
Step 3:
Now you are ready to remove the grip by twisting and pulling the grips up.
Step 4:
You're done! If, afterwards, you put the grip on another handlebars, do it while it's still wet; water eventually evaporates leaving the grip sitting very tightly.
