Introduction: How to Get an Animated Image As Your Google Chrome Background
I am going to teach you How to Get an Animated Image (gif) As Your Google Chrome Background. This is a way to make your Chromebook look better and you can choose the background that matches your style
All you need is your Chromebook and wifi.
Step 1: Next You Will Want to Go Into Google Chrome
Google chrome is the little red green and yellow circle thing with a blue inside on the bottom of the screen. If the black bar isn't at the bottom of your screen you may need to just move your cursor to the bottom and it should pop up.
Step 2: Now You Want to Look Up a .Gif Photo in the Search Bar at the Top of Google
Just search in google like gifs for background or something like that. If you don't like that search for different gifs that you like.
Step 3: How to Make Sure It Is a .Gif File
Once you found your .gif to make sure it IS a .gif you want to hover your cursor over the image. Use both fingers and gently press the mouse pad with both fingers at the same time. Once the white box pops up with all the options you will see "save image as.." click that and it should take you to "files" at the bottom where the name of the file is in blue look to the right of the name and make sure it is .gif and not .png or .jpeg. It must be .gif to work. if the file is not a .gif then simply press cancel
Step 4: Once You Have Your .Gif
Once you have your gif go to a new plain tab in google. In the bottom right corner there is a pencil, press it. once you have pressed it a white box will appear and you will press the "upload from device" and select the gif from your files then press open.
Step 5: Now You Have a Cool Customized Background for Google Chrome.
Now you know how to make a cool background. feel free to change it to a different gif if you dont like the one your using.
