Introduction: How to Get the Most Out of Your Workout
Do you work out regularly, but feel like you're not getting maximum results?
There are some things that you could be doing to sabotage your workout, or simply not allowing yourself to benefit from it as much as you could.
Here we will talk about the best ways to make sure you are optimizing your workout.
Step 1: Drink Lots of Water
This might be a no-brainer, but it's more important than you might think.  It's important to drink a lot of water while working out, especially if you are working hard and sweating a lot.  Your body needs water to replace those fluids, or else you won't be able to keep going.
Keep a water bottle with you at all times during your workout so you can easily keep hydrated.
Step 2: Eat Foods Rich in Protein After You're Done
If you are trying to build muscle, your body needs protein.  When you lift weights, you break down muscle fibers, and you need protein to be able to build them back up.  You should eat a good source of protein within an hour of your workout.
Some good sources of post-workout protein are lean meats like chicken or salmon, other sources like peanut butter or eggs, or you could also drink a protein shake.
Step 3: Stick to a Schedule
Of course you should work out at least a few times a week, but doing it at the same time every day is productive as well.  If you work out at different times of the day, your body is more likely to get worn out.  Stick to working out at the same time every day and you'll be more likely to stick to your gym routine.
Also, remember that shorter high-intensity workouts are better than long low-intensity workouts.  If you spend 30 to 45 minutes at the gym, it is sufficient if you are working out hard enough.
Step 4: Make the Most of Your Weight-lifting Reps
Don't go too quickly when you are lifting weights - this defeats the purpose and won't really give you a good workout.
The key is to go slow during every single rep.  If you go quickly, your muscles won't get the workout they deserve.
Step 5: Avoid Alcohol After a Workout
Some studies have shown that drinking alcohol after working out can decrease the positive effect that the workout has for your muscles and fitness.  So make sure you stay away from your daily glass of wine after you are finished at the gym.
Step 6: What to Do Next
If you work out every day, it is great for your overall wellness and you are probably already very healthy.  However, if you want to kick it up a notch, follow these steps and surely you will increase your overall fitness.
The most important thing to remember is to use your common sense; eat healthy foods from all the food groups, including grains, vegetables, fruits, and healthy fats.
