Introduction: How to Hack a Computer Atx Power Supply
Hi everyone, this is my first instructable and it's about how to Hack an ATX computer power supply and then put it in a nice little case so it's ready for use. I have made several of these before and decided to make an instructable about it. I will try to include as much detail in this instructable so sorry if I'm abit too wordy.
Yes i am aware that there are plenty of other hacks of this type but mine will be in lots of detail for anyone who has never hacked one before. This hack is paticularly useful when experimenting with motors, arduino or other mico controller circuits, to power a battery charger and any other electronic project that requires external power. I used the first one I made for about a year and it is still going strong, this is just V2.
First of all I would just like to say that the steps in this instructable are based around an Eagle DR-A350ATX power supply, unless you are useing the same power supply then the information in the instructable should be used as a guide only. I also take no responsibility for any injuries, property damge caused by steps given in this instructable, however if you follow the steps correctly you shouldn't have any problems. Also one final not you are working with potentially high voltages (paticularly inside the PSU its self) don't make the same mistake as me and work inside the PSU case while it is switch on or you may get a nasty shock.
TOOLS:
philips head screw driver
wire cutters
wire strippers
soldering iron
crimpers
files
drill with drill bits
Dremel (Optional)
MATERIALS: COST
1 ATX switching power supply $20 for a used one or pull one out of an old comp
1 switch $2
12 banana plugs $ 14 (at jaycar)
1 project box/ tupaware container $ 5 (at jaycar)
heat shrink tube
crimping connectors
various bit's of wire
zipties
superglue or epoxy
all of these materials can be bought online at jaycar.com.au
Plese forgive my spelling it is rather bad :(
Thanks and have fun
TOOLS:
wire cutters
wire strippers
soldering iron
crimpers
files
Dremel (Optional)
MATERIALS: COST
1 switch $2
heat shrink tube
crimping connectors
zipties
superglue or epoxy
Thanks and have fun
Step 1: Removing the Power Supply From a Computer Case
You can skip this step if you already have your PSU out of the computer case if not then read on.
Firstly you will need to remove the side pannel of your computer which is usually held in place by several screws on the rear of the case. Once these screws have been removed slide the panel towards the rear of the case and then lift it up and out (Your case may be different). Next identify the PSU and disconnect all of the wires leading from it, now remove the four screws that hold the psu in place on the rear of the computer case. Now just pull the power supply out and your done.
Step 2: Getting the PSU to Work
Now that you have your PSU plug it into the wall and try to turn it on. WOW IT DOESN'T WORK, that's perfectly normal, because there is no load being placed on the PSU. To fix this take a piece of shielded wire, strip the ends and place one end into the a black wire pin on the biggest plug. Now place the free end into one of the other coloured wires and turn on the PSU, if the fan spins up then it is working if not then take the end in the coloured wire terminal out and place it in another port. Try the green wire first! also sorry about the picture quality, not sure what went wrong.
Now that we have eablished the load wire connect a multimeter set to VDC to the psu pins to be sure that the voltages listed above are correct, if they aren't write them down on a piece of paper.
- (On a Standard ATX power supply
- yellow =12v,
- red = 5v,
- orange = 3.3v,
- white = - v
- blue =- v
- purple = v
- green = load wire ( the one that we need to turn it on)
Step 3: Mutilating the PSU
Now it's time for the fun step, where we get to cut apart the PSU. Begin this by taking the wire cutters and cutting off all of the computer connectors as close to the top of the terminal as possible. Then cut away any zipties holding the cables together. With this done open the PSU case by undoing the four screws in the top (Make sure you unplug the PSU before you do this!), now seperate the two halves of the case and then remove the cables from the black fitting that is holding them in the case. Now if you DON'T want to use negative voltages or the +5vsb (as in my example) cut them off inside the case and the place a piece of heatshrink tube over the top to prevent short circuits. If you do want to have negative voltage then just make sure in later steps you follow the additional instructions.
Once again sorry for the picture quality
Step 4: Marking and Drilling Holes in the Container
Now just put your PSU aside for a moment while we work on the case that will house the banana plugs and the power switch. You can use any old tupaware container, I just found it easier to by one from jaycar because they have a pre marked drill grid that makes drilling the holes quick and easy. I will post a picture of my layout however it is entierly up to you. Once you have marked out your holes drill them out with the recomended drill bit size slowly to avoid cracking the plastic on the other side. then give then a quick once over with a smooth file just to remove and burs. Do the same for your switch hole however if it is a square hole, you can use a smaller drill bit and then file out the hole using a square or triangular file or use a dremel.
Now see how your container is going to be positioned along with the PSU and drill a hole large enough for the cables to fit through. Once done file it to remove any burs.
If your adding the negative voltage wires in add in extra holes for them, you will also need extra banana plugs.
Step 5:
Now take all of your banana plugs and screw them into the holes you have just made being sure to tighten them completely. Then add in the switch and super glue or exoxy it in.
Step 6: Crimping and Soldering
Select three orange, red, yellow and six black wires as well as one more thin black wire and feed them through the hole in the side of the case. Now add a small circular crimping connector to each of the wires accept the thin black one. Once you have crimped all of the wires pull out the unnecissary wires and then arrange them in their respective colour groups, leaving the green wire in the case. Place all of the wires back in the black wire guard and then put the PSU case back together. Now take the green (or what ever your load wire was) and the thin black wire and solder them to the switch in any order, it doesn't matter.
Step 7: Connecting All the Wires Up
Now the real fun begins, NOT. When it comes to connecting the wires it turns out there is a right and a wrong way to do it, my first attempt was the wrong way. I will now tell you the way to do it that works and looks neat.
with this completed you will have a lid half attached and a lot of cables dangling around every where. Feed these cables in to the box in an orderly fassion and ly them in the bottom. Now seperate them agian into colour groups and then place some heat shrink over the wire, pushing it pown. then fold the top of the wire so it forms a sort of oval circle and contacts the rest of the wire, slide the heat shrink over the top and then shrink it inplace. Repeat this with all the loose wires and then ziptie them together just to be safe.
- Start closest to the switch with the three terminals working from left to right
- go to the first negative terminal and connect up two of the black wires
- then move to the next row of three terminals
- so on and so forth.... you get the idea
Step 8: Hoooooray Your DONE :P
Well almost the last thing you need to do is place the lid on and then screw it in place and then your done, that's all there is to it. Just turn it on and hook up a multi meter to be sure it's working.
Go on to the next step if your having problems.
thanks very much for reading my instructable and enjoy your new hacked PSU :P
Step 9: Trouble Shooting
Well your obviously here if your having problems getting your PSU to work,
SO have you tried turning it off and on again ?
- The IT CROWD
well have you?
Try using a multimeter to check for voltage between a 12V wire (usually Yellow) and a ground wire (Black)
If you follow these steps i will be more than happy to help :P
Jack
- The IT CROWD
well have you?
- check the switch on the rear off the PSU unit, ensure that it is on
- Check the switch on the switch pannel ensure that it is on
- unscrew the top pannel and using a wire bridge short between the two switch terminals (green and black wire)( if this makes it work replace the switch)
- check all of your connections and that they are correct
- What the problem is
- your power supply specs
- how old it is
- any other relevant information (stuff that occured whilst building, anything that may be a possible cause, dropping the PSU or extreme levels of dust.
Jack
