Introduction: How to Hang Some Tools With Nails
it can be annoying when you don't have a spot to put your tools so what I do is tap a nail or few into the wall depending on the size and shape of the tool. keep reading if you want to find out the best way to hang a hammer and other tools!
materials:
nails/screws (personally I like steel nails)
dry wall anchors (these are if you want to tools on drywall and you have a screw gun)
tools:
hammer/ screw gun,
stud finder (optional)
marker
Step 1: Figure Out Where You Want to Hang Your Tool
First, figure out where you want to hang your tool. use your stud finder to find the stud you want to hang your tool on. if you want your tool somewhere else you can use a drywall anchor to hang it.
Step 2: Mark Where the Nails Will Go
then press your tool to the wall, then mark the spots where you will tap your nails.
if your tool has a hole I would tap a nail and then slide the nail into the hole, and that's how I would hang a tool with a hole
to hang a hammer you can tap a nail under the hammer's neck and then another under the claw. in the picture, I marked the spots for nails in red.
Step 3: Tap All Your Nails Into the Spots Where You Marked
place your nail on the spot you marked and tap it into the wall(or where ever you marked)
Step 4: Hang Your Tool
hang your tool on the nails you taped in. again, if your tool has a hole slide the hole onto the nail.
Step 5: Label or Outline
Step 6: Done!
If you have any tips or ideas please leave a comment
And if you enjoyed this instructable please favorite this instructable.
