Introduction: How to Hang a Plant From the Ceiling
As someone with too many plants and pets, I like to hang whatever plants I can to keep them away from the animals! It also frees up space on my shelves for more plants.
I always hang my plants from the ceiling using a swag hook and an adjustable hanging chain.
Swag hooks are easy to install, safer than standard threaded hooks, and they look so much nicer, too. :) They come in a variety of sizes and weight limitations, so have a look around to find the best swag hook for your plants!
Keep reading and I'll tell you all about swag hooks and how to hang your plants from the ceiling!
Step 1: Tools and Materials
You don't need much, thankfully!
Tools to hang a plant:
- Swag hook
- Adjustable hanging chains
- Drill
- 5/8 inch drill bit (I'm using a spade style bit here)
And of course, some plants for hanging :D
Swag hooks are my absolute favorite tool to hang things from the ceiling. It's not always possible to use a stud, and these provide a safe alternative.
The one caveat with swag hooks: know the maximum weight! Every swag hook is rated for a different weight, so be sure to check yours and don't hang anything near the max weight. If the swag hook rips out of the ceiling, it's gonna be a bad time.
Step 2: How to Use a Swag Hook
How you use it all depends on what you end up drilling into!
If the drill sinks into drywall (also known as plasterboard or sheetrock, depending on where you live!) you're going to want to install the swag hook setup on the left. This swag hook includes a hinged clip at the top which anchors the hook against the opposite side of the drywall. (The clip opens flat once pushed through the hole, allowing you to screw the hook into place.)
If the drill sinks into a stud, you'll want to use the swag hook setup on the right. Use a drill bit slightly smaller than the screw and then use your hands or a set of plier to tighten the hook into place.
Step 3: Drilling a Hole for the Swag Hook
There's only one important thing to consider here: drilling in the right spot! Make sure you consider how plants will be spaced and how much light they'll get. Don't hang the hook too close to a wall so the plant rests against the wall and won't hang freely.
Use a drill with a 5/8 inch drill bit to make a hole in your ceiling.
Remember to switch out for a smaller drill bit if you hit a stud so you can install the screw-in swag hook.
P.S. Don't worry - these holes can be easily patched if you're renting! You can buy drywall patches and spackle in nearly any hardware store and it's a great skill to learn. For a more advanced technique, check out How to Fix a Hole in Drywall by mikeasaurus to learn how. :D
Step 4: How to Install the Swag Hook
Screw the hinged clip onto one end, and the hook on the other. Pinch the clip against the threaded rod and push it up through the hole.
Once it passes through the hole, you should hear and feel the clip's arms extending and becoming flat. Tug on the hook and make sure everything is sturdy, and then begin turning the hook until it's flush with the ceiling.
Tightening the hook sandwiches the drywall securely between the clip and hook so you can be extra sure it'll stay where it should. :D
Step 5: Hang Your Plants and Enjoy!
Use your adjustable chain to get the plant to the right height and gaze lovingly at your new air garden. I'd love to see a picture of them, too! :D
OH! And one last pro tip: if you have a vining plant (like my string of bananas here - over five feet!) that's growing really long, you can use adhesive hooks to drape the plant's vines and keep it out of harm's way. You may be able to see the tiny one I'm using on the left.
Adhesive hooks are also a lovely way to get a pothos, wandering jew or other vining plant to stretch out where you want them.
18 Comments
7 months ago on Step 5
Thank you thank you!!
Question 1 year ago on Step 5
Hi there,
Thanks for this post on installing swag hooks. Helped me a lot!
Question: what’s the best way to remove the hooks?
1 year ago
In your cover photo, what is that plant on the far right? I have a plant that looks similar and it’s dying. I can’t figure out what type of plant it is so I can help it.
Question 1 year ago
Hello, I just bought a 40 year old manufactured home. Do you know if this same technique can be used in my ceiling?
I want to hang some plants, and I have 2 vintage hanging lamps. I've never lived on a manufactured home before.
Thank you so much for your time and expertise!!
Kaylea
1 year ago
What is the heaviest plant you have hung without a joist? Some of the hooks have a fairly high weight limit but I am not sure I trust the hollow drywall to support a plant.
Reply 1 year ago
My golden pothos when totally wet is definitely over 10 pounds! Maybe closer to 15. Been hanging for over a year now with no issues. :)
1 year ago
How high is too high to hang plants?
Reply 1 year ago
It depends on the height of your ceilings and windows, but I always like to keep them 12-18 inches from the ceiling minimum. :) Too high, and they're awful hard to water and light may not reach the top of the plant!
2 years ago
BEAUTIFUL, ATTEMPTING NOT UNDERSTAND:)
Reply 1 year ago
Hi, you do not say how high is to high to hang plants?
1 year ago
Very informative. Just what I was searching for. Thanks so much!
2 years ago
Timing is perfect! Thank you for the push to free up our dining room table :)
Reply 2 years ago
Ha! In my case, it was my work table. Plants everywhere!
2 years ago
This seems like a great idea, especially because it is so easy to implement. I also love the images, especially the cover image. :) They are super sleek and professional.
Reply 2 years ago
Thank you very much! :)
2 years ago
I'm a plant fanatic myself. Thanks:)
2 years ago
amazing way to enjoy a green view.
2 years ago
Your plants are so lively and fancy :)
