Introduction: How to Hook Up a Lure on Fishing Line
For this Instructable, I am going to be showing you how to tie on the hook and weight onto a fishing line easily.
Step 1: Materials
Barrel swivel
Fishing line
Dipsy (Weight)
Hook (On string)
Fishing line
Dipsy (Weight)
Hook (On string)
Step 2: Tie
Put the string through either end of the swivel, then cross underneath and go through the loop that is now created. Do not pull it through yet.
Step 3: Tie
Go around the line at the top and back through the 1st loop. You can then pull it through. Do the same to your weight on the same piece of string. Cut off any extra.
Step 4: Putting the Hook On
Put the loop on the hook through the other swivel hole and put the hook through the loop. Pull it through carefully and get something like a pair of needle nose pliers or cork to pull a little more
Step 5: Fin-ish! Get It? No? Okay...
Now just put your bait on and cast! Its as simple as this.
