Introduction: How to Import Java Projects Into Eclipse for Beginners
Introduction
The following instructions provide step by step guidance for installing Java projects onto the computer software Eclipse. Java projects contain all code, interfaces, and files necessary for creating a Java program. These projects are placed in a unique workspace directory. When installing these files from a separate source, they must be placed correctly within the files of the computer to be properly located by Eclipse. This simple instruction set aims to assist beginners in this task.
Disclaimer!
The instruction set uses the Java project algs4 as an example. This particular Java project is adapted from the textbook Algorithms by Robert Sedgewick. This contains the example and assignment files that go along with the textbook’s material. In addition, the examples below use a PC, though the process is nearly identical on a Mac.
Step 1: Obtain the Java Files You Wish to Install
Obtain the Java files you wish to install to Eclipse by downloading them from their source. The files will be in a zip file.
Step 2: Create a New Folder
Create a new folder on your device for the Java files by right clicking and navigating to :
New > Folder
The workspace directory folder and its Java project subfolders will be placed in this location
Step 3: Extract All Contents of Zip Folder
Extract the contents of the downloaded zip file into the folder created in Step #2. Right click and press “Extract All...,” choose the correct location path, and then press “Extract”.
Step 4: Initialize Eclipse
Once the files are properly downloaded and placed into an accessible folder, initialize Eclipse.
Disclaimer: Eclipse is a complex software that often takes a few minutes to initialize.
Step 5: Select Workspace Directory
Eclipse will prompt the user to select a workspace directory. Select the folder representing the correct workspace directory by selecting “Browse” and searching for it. In the example, the folder is titled workspace.
Step 6: Launch Eclipse
Once a workspace directory is selected, press “Launch” and Eclipse will proceed to load in this location.
Step 7: Create a New Project in the Workspace Directory
Create a new project in the workspace directory by navigating to :
File > New > Java Project
Step 8: Identify and Type in Java Project Name
Identify the Java project subfolder you wish to import. In this case, the project is titled algs4. Type the name of this folder in under “Project Name”.
Step 9: Adjust Execution Environment
Make sure the execution environment is appropriate for the files you are importing. In this case, JavaSE-1.8 is the JRE (Java Runtime Environment) required.
Step 10: Finish
If the note in Figure 10 is shown, press “Finish” to create project. If not, restart the process, double checking each step.
Step 11: Conclusion
Congratulations! The Java files should now be properly installed and ready for use.
It is vital to maintain the organization of folders and subfolders as is in order to access this code each time Eclipse is launched.
This set has provided step by step guidance for installing Java projects onto the computer software Eclipse. Enjoy programming!
