Introduction: How to Increase Font Size on IPhone
Dear friends, when you’re browsing the Web or reading an article on your iPhone or iPad, you want the text to be as big as possible. There are cases when you need the font to be enlarged in your iPhone. Those are usually associated with vision difficulties. There is an option in iOS to enlarge text for readability and well being.
If you have vision problems and have trouble seeing small text on your iPhone or iPad, you can increase the font size for better readability. It is easy to increase the font size on iOS for general apps, and even more importantly, you can set a custom font size for individual apps.
You can change the font in nearly every app, but for your home screen and apps like Settings you’ll need to change a setting. There are even a couple of options for changing the font style.
Turning up the font size on iPhone can make life a lot easier if you have trouble reading fine print. Whether is it because of age, poor eyesight, or simply because you spend a lot of time checking your phone, bigger fonts are easier to see and read.
Step 1: How to Make the IPhone Fonts Bold
If making the text size is not enough, you can make the font bold to make it appear easy on your eyes. Here is how you can turn text bold in iPhone:
  1. Open Settings on your iPhone
  2. Go to Display & Brightness.
  3. Now Enable Bold Text feature.
If you own an iPhone and somehow didn’t know about this simple trick, now you know. This little tip can help you make your iPhone easier on the eyes. With bolder fonts, the text will appear bigger than if it were in a regular weight.
Step 2: Adjust IPhone Text Size Using Accessibility Settings
If you want to make the text even larger and easier to read, you can use Accessibility settings. Another way to make text even easier to read can be found in your settings. Tapping Display & Text Size will take you to a detailed menu where you can change font, text size, and text.
  1. Open Settings and tap Accessibility.
  2. Go to Display then Text Size.
  3. Click on Larger Text.
  4. Toggle on Larger Accessibility Sizes.
  5. Drag the slider to increase or decrease the text size.
This will make the text on your iPhone larger, easier to read and more comfortable to look at.
Step 3: Make Font Size Larger on IPhone Using Display & Brightness
You may enlarge the font on your iPhone and iPad by tapping Settings > Display & Brightness. In there, you'll see the option named "Text Size," which lets you choose from smaller to larger sizes.
