Introduction: How to Insert a PDF File Into PowerPoint
Sometimes we just want to reuse a PDF file for our PowerPoint presentation, but you will find it not that convenient to do so. "Copy and paste" method may be feasible if you lucky enough. As PDF files can be restricted from copying and only well tagged one is easy to copy without info loss. Below I will introduce you two methods to inert a PDF into PowerPoint .
The first method maybe many of you have tried or will try later when you need to insert PDF into PPT file. That is to hover over Ms PowerPoint itself to see if there is existing insert function to let you import PDF file into PPT presentation.
The answer is "Yes", but I’d like to make you clear that actually you can just import the first page of the file per time and it will be inserted as picture.
Here let me take Ms PowerPoint 2007 for example:
You can either create a new slide to put PDF content on or add to existing slide. Below are conjunct steps: Insert> Object> you will see "Adobe Acrobat Document" is at the first place of the file type> click "Ok" directly > browse your local files to open the PDF file you want to add> switch to Adobe reader> "File" to "Exit and return to Presentation Name"> Voila. Then you can resize it by drag the blue border but you are not able to edit the image.
I think you may have the same feeling like me is that if only there is a way to export PDF to PowerPoint file more efficiently and even you can freely edit the file to fit your presentation, that will be great.
Then you need a PDF to PowerPoint Converter to insert a PDF into PowerPoint effortlessly and gain editable feature for better reuse as PPT slides.
Below is the step by step instruction to insert PDF into PPT file:
Free download PDF to PowerPoint Converter then install and open it. Next simple manipulations are in an intuitive interface.
Firt step: Click "Add Files" to batch input your PDF files into the file list. It will convert them to PPT files at one time and each page into one separate slide.
Final step: Customize an output folder saving place and click "Convert" to start the conversion.
Then open the output folder, you will see the original PDF files have been converted to editable PPT slides and all the content such as text, image, charts, graphics, etc is well retained.
If necessary you can modify them, then import PDF file into PPT presentation as below:
Open your PPT file and turn to certain page after which you want to add PDF file. Home> Create New slides> drop-down list> Slides (from outline)> import target converted PPT file from local disc
See how easy it is to go with a PDF to PowerPoint Converter, you will make seamlessly combination and reuse any content from desired PDF files including password protected files. Especially for teachers, businessmen, and so on who frequently use a presentation, export PDF to PowerPoint file directly will help a lot.
