Introduction: How to Install Lighted Address Numbers
Transform your home with LED Modern Backlit House Address Numbers - the perfect blend of practicality, elegance, and visibility. Illuminate your address with our long-lasting, eye-catching LED lighting technology, easily mounted on any surface including brick, wood, stone, stucco, and siding. Make your home stand out and be easily identifiable with our modern and stylish backlit house numbers. rock, & many more.
You can get your Lighted House Address Numbers from this link
- Backlit address numbers
- LED Driver - 110V AC to 12V DC converter transformer
- Installation template
- Mounting screws
- 14AWG wire
- (Optional) Plug
- (Optional) Timer Auto On/Off
- (Optional) Dusk to Dawn Light Auto On/Of
- (Optional) Dimmer
- Painters tape
- Drill
- 5/32" drill bit
- Level
- Exterior grade epoxy
Step 1:
- Before you start the installation process, please read our caution at the bottom of this page.
- Tape the included installation template to the wall and drill holes for the screws and the wires at the designated marks on the template using a 5/32" drill bit.
- Screw the screws into the holes on the back of the backlit numbers.
- Add some epoxy to the other end of the screws at the back of the backlit numbers.
- Remove the installation template and mount the backlit numbers on the wall by aligning the screws to the holes you drilled in the wall and pushing the screws into the holes.
- (Skip this step and move to either the next step or the one after if you purchased either the dusk to dawn light sensor or the timer). Connect all the positive (white)wires of the numbers to the positive (brown) wire on the DC side of LED driver and connect all the negative (black & white) wires of the numbers to the negative (black) wire on the DC side of the LED driver. Skip the next two steps if you didn't purchase the timer or the light sensor.
- Optional (only if ordered light sensor):
- Connect all the positive wires (white)of the numbers to the positive (red) wire on the OUT side (the side that has two wires) of the light sensor.
- Connect all the negative wires (black & white)of the numbers to the negative (black) wire on the OUT side (the side that has two wires) of the light sensor.
- Connect the positive (red)wire on the IN side (the side that has three wires) of the light sensor to the positive (brown) wire on the DC side of the LED driver.
- Connect the negative (black)wire on the IN side (the side that has three wires) of the light sensor to the negative (black) wire on the DC side of the LED driver.
- Optional (only if ordered timer):
- Connect all the positive wires (white)of the numbers to the right side of the switch terminal of the timer.
- Connect all the negative wires (black & white)of the numbers to the negative side of the power terminal on the timer.
- Connect all the negative wires (black & white)of the numbers to negative (black) wire on the DC side of the LED driver.
- Connect the positive wire (brown)on the DC side of the LED driver to the left side of the switch terminal of the timer.
- Connect the positive wire (brown)on the DC side of the LED driver to the positive side of the power terminal of the timer.
- Connect the positive (red)wire on the AC side of the LED driver to the positive wire of the AC power source and connect the negative (red) wire on the AC side of the LED driver to the negative wire of the AC power source.
