Introduction: How to Install Lowering Springs | Chevy Cruze
Freddy from PoorManMods shows you how to install lowering springs by installing a set of God Speed lowering springs on a 2013 Chevy cruze. This is a step by step for the chevy cruze, but the overall process can be applied to many vehicles.
Springs installed in this video: https://amzn.to/3dspHp2
Spring Compressor https://amzn.to/32typ44
Pass through socket set https://amzn.to/3ySeIPI
Step 1: Remove the Front Strut
Remove the front strut:
- Remove the top nut
- Raise the car up and remove the wheel
- With a pass through socket and allen wrench remove the nut from the sway bar end link
- Remove the 2 bolts securing the bottom of the strut
- Remove the Strut
Step 2: Remove Front Spring
- Use a spring compressor to compress the spring
- Once compressed remove the top strut nut
- Remove the spring from the strut
- Place the new/lowering spring onto the strut
- Compress the spring and install the top nut
Step 3: Reinstall Front Strut
- Reinstall strut into car
- Reinstall the hardware you previous removed
- lower car onto the ground, allowing strut to protrude through the mount in the engine bay
- install top washer and nut
Step 4: Remove Rear Spring
- Place a jack/support under the control arm or rear beam
- Remove the lower shock bolt to allow control arm to drop
- remove the spring
Step 5: Install Spring
- Install new/lowering spring
- Align shock and reinstall bolt
- Remove jack/support
- You're done!
