Introduction: How to Install Prebond Extensions Using Shrinkies
If you're looking for an installation method that won't slip but still has all the movement and conceal-ability of prebond, shrinkies are for you! In this video Doc will show you step-by-step how to install this heated extension method!
For this tutorial you will need:
Grab your heat tool and follow along in the video!
Step 1: Section
Slide the Shrinkies onto the pulling needle.Carve off a section of hair and slide one Shrinkie onto the natural hair.
Step 2: Add Extension Bond
Insert the tip of the extension hair into the Shrinkie.
Step 3: Add Heat
Apply heat to the Shrinkie using a heat wand. Roll the bond into place.
Step 4: Double Check
Do a rotation test and reposition if needed. Repeat until desired style is reached.
